Results 1,331 to 1,340 of 2023
- Oct 2006
- 58
November 13th, 2006 08:52 AM #1331Isn't it the fuel filter's job to remove foreign particles from dirty fuel e.g. rust from tanks, pipes etc?
November 13th, 2006 08:54 AM #1332
November 13th, 2006 05:37 PM #1333
November 13th, 2006 06:27 PM #1334
my unit is 2.5D4D pinalitan last april 2006 odo 5,000km, nun una sabi ok na wala daw problem sa supply pump, hula ko reprogram lang nila, after 300km of travel lumala, so binalik ko sa ibang casa sa manila bay, pinalitan na supply pump, right now nasa 8,500 kms na, ok naman starting , problem is lumakas fuel consumption niya, highway driving no traffic (la union to laoag) nasa 9.2 km/liters lang
November 13th, 2006 06:36 PM #1335
November 13th, 2006 06:50 PM #1336
Sa tingin ko hindi uso yong reprogram nung palitan nila yong supply pump mo kasi aril pa pala May or June lumapas yon bagong program. what they did is they initialize your unit then nung bumalik yong problem pinalitan na yong supply pump. Magkaiba kasi yong Initialization sa Reprogramming.
November 13th, 2006 06:55 PM #1337
November 13th, 2006 09:30 PM #1338
kung ang ginawa lang nila eh i-reporgram yun axle problem, alam mo na talaga kung ano pakay nila hehehe
November 14th, 2006 09:49 PM #1339
November 14th, 2006 10:02 PM #1340
if the fuel consumption became higher after reprogramming, maybe the toyota techs adjusted it so that more fuel goes thru the fuel pump. remember, it is diesel itself that lubricates the supply pump. maybe they reprogrammed it that way to provide more lubrication to the pump so that it will not fail sooner.
high idle RPM at engine start
