Results 601 to 610 of 2023
January 25th, 2006 11:49 AM #601
Guys,
I had that same problem yung namamatay ang engine after start up. One thing siguro, is baka you are using the wrong key! I think for the G variant, you need to use the key na may DIN number kasi gamit yung for safety ( anti carnapping). After using the required key, okay na ulit ako.
Please try mo rin yung M2M. Dont use the spare key. Thanks
January 25th, 2006 02:09 PM #603
same thing happened to me when i had my innova checked -engine start up stalling. they need to to have the diagnostic machine attached when the engined stalled. kaya lang hindi ako pumayag since that would mean they will have to start up the engine over and over again until the stalling can be observe. good thing meron akong nakuhang video on my innova showing the tachometer when it still had the problem. sabi ng warranty claim advisor, the video can be use as an evidence na raw.
im still waiting for the parts to arrive but i'm not in a hurry cause its been 3 weeks now hindi pa nag recurr ang problem
- Jan 2006
- 55
January 25th, 2006 04:54 PM #604Originally Posted by aaron drin
Bongliza, if its not too far from where you are staying, why dont you try Toyota Ortigas...i gather Ortigas and Shaw are from different owners than those from Alabang, and it seems they are more responsive to the 4d4 problems.
January 25th, 2006 05:11 PM #605Originally Posted by bongliza
Hindi parin alam ng Toyota ang problema.Naghintay lang sila na ma-expire yong warranty natin at tapos ang problema nila,kikita pa sila pag nasira ulit yon pump or CRDi kasi sa kanila tyo bibili.Ano sa tingin nyo parang sadya yata ito para mas malaki ang kita nila.I remember 2C engine nila disposable yon pag umusok na tapon na parang ganito din ito.
January 25th, 2006 05:27 PM #606
Kailangan pa ba i analyze? di pa ba nila tanggap palpak ang Fuel injectors nila? dapat recall na nila. Im planning to buy gas next month.
Tsikot Member Rank 3
- Sep 2003
- 786
January 25th, 2006 11:24 PM #607Originally Posted by Isuzoom
January 26th, 2006 09:04 AM #608
M2m,
Good to hear that your car is ko na. Sana, mine hindi mag ka problem. Im more than 5,000 km na and just finished my 2nd PM using Biodiesel fromChemrez (hotline nila 635-9000). So far, so good!
I already informed Toyota Motor Phils. Hope they will attend to this. Sabi nila, it is because of the fuel , kung ganon, dapat limit your self to one fuel source lang, one station, one brand,
- Jan 2006
- 58
January 26th, 2006 09:29 AM #609gud am, if i may join the forum and put up one Q. the D4D woes, is this problem unique for this type of engine o other diesel engines can also be prone to the problems mentioned? kasi am planning to buy a second hand sedona and i know its diesel, but i dont know kung anong klaseng engine nya. medyo may kaba na ako sa diesel engine reading this thread. opine please
- Jan 2006
- 55
January 26th, 2006 09:56 AM #610Originally Posted by aaron drin
Ive been limiting myself to use only Petron from the same gas station for my fuel source, just to eliminate the fuel issue.
high idle RPM at engine start
