Results 1 to 10 of 55
- Aug 2009
- 35
August 30th, 2009 11:43 PM #1Hello everyone! A friend of mine introduced me to this forum
and have read with interest some of the topics posted here.
I have some concerns with my 1995 Corolla GLi (4AFE engine,
16 valve - stock) as my friend could not answer all my questions.
I am hoping for some help, guys.
1. Idling seems to be okay when the A/C is turned on. However,
it goes down to around 750 (i believe) and the engine "nangingingig"
ng konti (but not to the point na it will die down. It then returns
to around 900-1000 RPM when A/C "engages". Is this normal?
2. When A/C is off, idling (RPM) is around 750 (according to
the results from an analyzer used at Servitek) - nanginginig
ng konti ang makina - but di naman namamatay. Is this normal?
3. After starting the car, I turn on the A/C, then drive. Ok naman
ang lamig (nasa 1 setting lang ako parati). However, I noticed
na pag natrapik ako, full stop, blower na lang ang nararamdaman
ko (wala na yung lamig).
Di na rin nag-auautomatic yung A/C. I tried putting the A/C setting
into 2, 3, and 4 - kaso ganun pa rin.
Babalik na lang to normal operation yung A/C pag tumatakbo na uli
ang car.
What could be the problem, guys? Please help!
This is my first post, nga pala. Sana may makatulong sa akin.
Thank you, fellow Tsikot members!
P.S.
Less than 4 weeks ago, I had my coolant, brake fluid, and
power steering replaced. I also replaced all my spark plugs
and air filter, as well as changed my engine oil, fuel filter, and oil filter.
I have also just used the Mitsubishi Fuel System Cleaner -
dito ko nabasa at natutunan yun
I have also just purchased a set of new tires for it.
Except for the above-mentioned concerns, maayos ang
takbo ng car - matipid (9-10 km city driving) - malakas ang hatak
at matulin. And never siya nag-overheat.
Thank you, fellow Tsikot members for your help!
August 30th, 2009 11:55 PM #2
typically normal for most cars of the type.
ang car.
- Aug 2009
- 35
August 30th, 2009 11:59 PM #3
August 31st, 2009 12:02 AM #4
Ipa check nyo po siguro yung aircon system like auxilliary fan, compressor, evaporator, thermostat sa isang reputable car aircon repair shop. Malamang baka madumi na rin yung evaporator nyan dapat maipalinis at maipa leaktest para malaman kung may butas or baka kulang lang sa karga ng freon.
- Aug 2009
- 35
August 31st, 2009 12:05 AM #5
August 31st, 2009 12:40 AM #6
- Aug 2009
- 35
August 31st, 2009 12:50 AM #7Hi Ghosthunter!
My thinking was to adjust it a bit (from 750 to 800 RPM).
Gusto ko lang sanang matangal yung "konting nginig"
when it is in neutral.
I asked the mechanic kung puwede i-adjust - pero sabi
niya yung ECU ang automatic nag-aadjust nun
based on the sensors found in the Corolla GLi.
Hoping for your help again, Ghosthunter.
Thank you very much!
August 31st, 2009 12:58 AM #8
- Aug 2009
- 35
August 31st, 2009 01:13 AM #9This info is a big help, Ghosthunter!
I will have my mechanic take a look tomorrow.
Bigla tuloy ako napaisip - do you know any
very good Corolla GLi mechanics and/or electricians, Ghosthunter?
Makati area ako, but I also frequent Alabang, Sucat and
Bicutan.
Thank you so much!
- Sep 2003
- 10
Kami dati naglalagay ng chain lock ng motor or bike. Iba nakita ko literal na kadena at padlock.
