Results 1 to 20 of 55
    Aug 2009
    Hello everyone! A friend of mine introduced me to this forum
    and have read with interest some of the topics posted here.
    I have some concerns with my 1995 Corolla GLi (4AFE engine,
    16 valve - stock) as my friend could not answer all my questions.
    I am hoping for some help, guys.
    1. Idling seems to be okay when the A/C is turned on. However,
    it goes down to around 750 (i believe) and the engine "nangingingig"
    ng konti (but not to the point na it will die down. It then returns
    to around 900-1000 RPM when A/C "engages". Is this normal?
    2. When A/C is off, idling (RPM) is around 750 (according to
    the results from an analyzer used at Servitek) - nanginginig
    ng konti ang makina - but di naman namamatay. Is this normal?
    3. After starting the car, I turn on the A/C, then drive. Ok naman
    ang lamig (nasa 1 setting lang ako parati). However, I noticed
    na pag natrapik ako, full stop, blower na lang ang nararamdaman
    ko (wala na yung lamig).
    Di na rin nag-auautomatic yung A/C. I tried putting the A/C setting
    into 2, 3, and 4 - kaso ganun pa rin.
    Babalik na lang to normal operation yung A/C pag tumatakbo na uli
    ang car.
    What could be the problem, guys? Please help!
    This is my first post, nga pala. Sana may makatulong sa akin.
    Thank you, fellow Tsikot members!
    P.S.
    Less than 4 weeks ago, I had my coolant, brake fluid, and
    power steering replaced. I also replaced all my spark plugs
    and air filter, as well as changed my engine oil, fuel filter, and oil filter.
    I have also just used the Mitsubishi Fuel System Cleaner -
    dito ko nabasa at natutunan yun
    I have also just purchased a set of new tires for it.
    Except for the above-mentioned concerns, maayos ang
    takbo ng car - matipid (9-10 km city driving) - malakas ang hatak
    at matulin. And never siya nag-overheat.
    Thank you, fellow Tsikot members for your help!
    Quote Originally Posted by margaret View Post
    typically normal for most cars of the type.
    normal
    ang car.
    Sounds like your freon is low or there is a leak. Have your A/C system recharged with freon. If the problem returns, have it checked for leaks.
    Aug 2009
    Could the idle/timing be adjusted on a Corolla GLi, Ghosthunter?
    Thank you very much for the suggestion. I will do so this coming
    Saturday. I've read about CeeJay's here, too.
    Again, thank you very much for the suggestions!
    Yes but you will end up consuming more fuel if you increase the rpm of the idle.
    Aug 2009
    Hi Ghosthunter!
    My thinking was to adjust it a bit (from 750 to 800 RPM).
    Gusto ko lang sanang matangal yung "konting nginig"
    when it is in neutral.
    I asked the mechanic kung puwede i-adjust - pero sabi
    niya yung ECU ang automatic nag-aadjust nun
    based on the sensors found in the Corolla GLi.
    Hoping for your help again, Ghosthunter.
    Thank you very much!
    Hi Ghosthunter!
    The idle speed adjustment screw is on the front of throttle body in a recessed hole (driver's side).
    Apr 2008
    Ipa check nyo po siguro yung aircon system like auxilliary fan, compressor, evaporator, thermostat sa isang reputable car aircon repair shop. Malamang baka madumi na rin yung evaporator nyan dapat maipalinis at maipa leaktest para malaman kung may butas or baka kulang lang sa karga ng freon.
    Aug 2009
    Thank you for the suggestions. I will be listing these down, too,
    when I have the car for check up this coming weekend.
    Quote Originally Posted by susmaryousef View Post
    ang car.
    this may be "normal" for some toyotas of this vintage. go to an honest and knowledgeable aircon shop and tell the guy about it. he will make some electrical connection changes.
    Paki check na rin kung gumagana auxillary fan mo. O pa check mo na lang muna sa aircon repair shop para makita kung ano dahilan sa problema mo sa aircon.
    Aug 2009
    According to my brother, gumagana yung aux fan.
    Ill have it checked as soon as my sched permits me to do so.
    Toxic talaga sa work for the past few days...
    Quote Originally Posted by speed unlimited View Post
    Aug 2009
    Thank you very much for the suggestion!
Toyota Corolla GLi Idling & AirCon
