Page 50 of 50 FirstFirst ... 404647484950
Results 491 to 500 of 500
    #491
    Quote Originally Posted by reymund View Post
    May pinapalitan bang something dun sa door area kung halimbawang yung tunog pag sinara pinto parng hindi na sya kagaya nung bago bago pa? Napansin ko mejo iba na tunog lately..
    Sent from my SM-A710F using Tapatalk
    that's difficult to assess from where i sit, as i have no idea what the new sound, sounds like.
    but i would inspect the bolts, if they are tightened.
    also, the door upholstery, if everything is seated and pinned down properly.
    then the rubber weather strip, if it is intact and in place.
    i would open it, if i thought from the sound, that something inside could be causing the unusual sound.
    and if it doesn't close "easily", i would check for door alignment or lock mechanism alignment, including bolt tightness.
    i would see if the hinges need lubrication.
    Apr 2016
    #492
    Hi po. Up ko lang po ito
    Nagkaissue po ba kayo sa odometer ng big body? Gumagana naman po speedometer and tachometer, kaso yung odometer and trip meter di na gumagalaw Ang suspetsa ko po is yung gears lang po kasi may mga times na gumagana siya, tatakbo ng 1 km, then hinto na ulit. May change pa bang maayos ito? Kasi as much as I can, gusto ko po i-retain yung legit mileage niya. Thank you po sa mga makakasagot.
    Oct 2018
    #493
    Mga paps, may mairerecomend ba kayo na mechanic or shop na expert sa lovelife?
    Apr 2009
    #494
    Ano dapat fuel consumption ng big body gli? Rifht now 5km per liter sakin. 135k mileage. Is this normal?
    #495
    Quote Originally Posted by bail View Post
    it depends, on the traffic.
    if traffic isn't bad and you are getting 5 km/li...
    it might not be the gas.. it may be the engine that needs fixin'.
    Sep 2005
    #496
    Sep 2018
    #497
    what could be wrong, namamatayan ako ng makina habang naandar. i put the gear in neutral and start the engine again, then put in D.
    history:
    1. replaced busted distributor(tumirik ako d2). ok na umandar na then umaandar nmn agad pg namatay makina(good sign daw un na ok ung dist as per mechanic)
    2. ginamit ko, namatayan, put in N start engine then start again, put in D. this happens a lot, nag palit na ng fuel pump kasi nakita ns mahina buga dun sa luma. what do you think other areas need to consider, thanks.
    Sent from my SM-A505GN using Tapatalk
    May 2008
    #498
    anybody know the size for front camber bolts ng ae101. hindi pareho yung butas ng shock struts na nabili ko. nagiba yung camber. baka macorrect yung camber kesa kikilin yung butas ng strut.
    Jun 2011
    #499
    Nov 2023
    #500
    May ma recommend kayo mga sir na mechanic na expert sa corolla bigbody na matic? around san mateo - marikina area sana. pwede din kung naghohome service (san mateo area).
Toyota Corolla AE101 Owners & Discussions [Merged]
