Results 5,021 to 5,030 of 5535
- Aug 2013
- 262
May 23rd, 2018 09:20 AM #5021
May 23rd, 2018 09:27 AM #5022
- Jul 2016
- 939
May 25th, 2018 01:26 AM #502399% compressor problem nyan sir.
Around 28k bili namin dati bnew.. Add mo na labor, cleaning and filter/drier. Ready ka na 35k.
Clutchless type sya, Ung solenoid ang nagloloko dyan, sya nag aadjust nung compression ratio, ie turning ON and OFF ng compressor.
Kaya minsan, normal lamig, minsan wala, or minsan hilaw lamig.
- 54,205
May 25th, 2018 07:34 AM #5024
May 25th, 2018 02:03 PM #5025
Ang mahal pala nung culprit ng aircon ko. Nangyari ulit twice nung isang araw. Nakastandby lang ako may inaantay around 30mins. Nawala bigla un lamig, hangin lang. tapos after 15mins naulit ulit na nawala un lamig.
28k dati? Ilan years ago na un sir? Most likely tumaas na price ngayon. For 10.5 gen pala un akin sir.
- Mar 2018
- 263
May 25th, 2018 06:37 PM #5026Possible na bearing lang, although sisirain din eventually compressor. The aircon shop should be abke to tell if your compressor is still okay. Encountered the same problem with a Jazz. Bearing replacement inclusive of labor is 6k. According to the mechanic, they reolaced a lot of those bearings sa vioses as well.
Sent from my ONEPLUS A3003 using Tapatalk
May 25th, 2018 06:43 PM #5027
- Mar 2018
- 263
May 25th, 2018 06:53 PM #5028Based on the mechanic's explanation, me sira ang bearing to the point the intermittent ang pag kapit nya sa compressor. I actually check 4 aircon shops, yung isa compressor daw, the other one non commital gusto baklasin muna, the i have a common diagnosis na bearing so I proceeded with the repair. I think the lube (silicon oil) is more applicable sa clutch assemby ng mga radiator fans, which can also cause the same symptoms although mas consistent.
May 26th, 2018 02:35 AM #5029
Salamat sa mga input sir. At least may idea na ako ano un possible problems sa aircon.
- Jul 2016
- 939
May 26th, 2018 12:59 PM #5030
If you don't have a spare tire, a tire inflator using the socket of the car as power outlet is the...
Liquid tire sealant
