Results 2,641 to 2,650 of 3381
- Mar 2014
- 97
- Apr 2004
- 20
February 1st, 2016 10:28 PM #2642Anyone who experience this?..rpm'drops when engaging clutch 1st gear usually and 2nd gear also.you have to put some'gas in order to get more rpm so that the body will not vibrate or the engine dies.clutch is still good coz acceleration is fast.the only prob is the rpm drops down when engaging usually in 1st gear n 2nd.i already clean the maf sensor and the throttle valve with the spray throttle cleaner.
February 27th, 2016 09:58 PM #2643
Nakaka sludge ba pag hindi masyado nagagamit yung auto? Once a week lang?
February 28th, 2016 11:06 AM #2644
Is top end RPM still good or hirap yung engine to hit redline as well? If that happens, one possibility is the MAF is off-soec already. Re dropping RPM, perhaps an engine scan can help if you tried the possible culprit. I have the same problem on our 9th gen and the issue is the MAF which we have to replace.
As long as you get an service every year, and use a good oil and oil filter, should not be a problem. Make sure to drive the car hard once in a while too. Perhaps, akyat mo sa Skyway and drive it at 100-110kph on 3rd gear if conditions allow.
February 28th, 2016 03:12 PM #2645
Hi vinj, won't a defective MAF Sensor light up the engine fault indicator on the dash? If not, how did the scan reveal this?
February 28th, 2016 07:08 PM #2646
- Aug 2015
- 12
February 29th, 2016 06:19 PM #2647Hi Guys,
Ok ba yung Tein H Tech sa Altis 10.5 Gen? From those who are experienced in lowering their rides.
I'm thinking if I should improve my handling and height. All stock suspension ko. Any other items
to consider to avoid mismatch sa lowering springs? Thanks!
February 29th, 2016 07:12 PM #2648
- Aug 2015
- 12
March 1st, 2016 11:08 AM #2649
- Apr 2016
- 1
April 29th, 2016 09:21 PM #2650
Hinde na kailangan niyan. Trying hard to be developed country nanaman si kingkong tugade. ...
[AI] Here's what they'll check during MVIS...
