Page 329 of 358 FirstFirst ... 229279319325326327328329330331332333339 ... LastLast
Results 3,281 to 3,290 of 3575
    Mar 2020
    #3281
    Quote Originally Posted by 2lits17 View Post
    20k lang pala. so pareho lang sila ng normal plugs? i replace the normal Denso plugs every 20k. will there be a real difference from a normal plug? better fuel consumption??
    noted as oil drain plug. i'll just buy sa casa mura lang pala.
    They would only improve performance and fuel economy only if your plugs are worn out in the first place
    Sent from my LGM-G600L using Tapatalk
    #3282
    sorry sakin lang yan bro
    i replace copper plugs every 10k km, plat every 20k km or every year during my bday month hehehe
    pero your post got me thinking. mas maganda siguro every year nalang ako magpalit then use copper nalang. [emoji848][emoji848]
    Mar 2020
    #3283
    Just out of curiosity, why not use OEM Iridiums? My Altis has the same set of plugs from 2013 and it still drives like new
    Aug 2012
    #3284
    how much per set? i had tried to canvass last time sa lazada.
    Denso Spark plug (iridium) IK16TT - 2,800
    Denso K16TT Spark plug (ordinary) - 500
    how long is the change interval of iridium plugs?
    *ninjabez
    maybe yearly will be good enough. of course depends on the KM you use per year.
    mejo nanghihinayang din kasi ako sa performance sparks since mostly city driving lang naman ako and occasion out of town trip.
    Mar 2020
    #3285
    *ninjabez
    In the Altis owner's manual, it says that Iridiums should last 100k km. Mine's been on since 2013 and close to 80k km
    #3286
    Quote Originally Posted by BrokeStudent View Post
    those estimates can and usually, go beyond expectation.
    as long as the electrodes are not deformed, they should be still useful and not get replaced "because the manual says so".
    #3287
    dapat isama ng toyota sa 80k km check ito
    flushed 15-20k km old coolant
    cleaned reservoir narin
    Sent from my Redmi Note 9 Pro using Tapatalk
    #3288
    OMG why is my check engine light lit up!!!! Baka nag sludge car ko!!! I tried to run it today and then it opened pa using the alarm pero ayaw na mag start!!!
    #3289
    scan natin auto mo cathy
    baka bumigay na yung battery mo, di mo na start pero ON CEL? normal yan
    #3290
    Ano scanner mo bro?
    Sent from my ONEPLUS A6013 using Tapatalk
Toyota Corolla 10th Generation Altis Owners [continued]
