Results 2,491 to 2,500 of 3568
August 13th, 2015 10:16 AM #2491
Dont believe those lifetime oils. Better to just replace every 40,000kms at the least.
On brake pads, OEM Toyota will cost around 3K, Bendix CTs around 900+. If you can afford the Toyotas, go for them.
August 13th, 2015 01:21 PM #2492
Our old 98 model manual sentra still has the original trans.oil in it up to present. Haven't changed it yet coz when we have it checked twice a year the mechanic always says it's still good and clean.[emoji4]
Never had any problems.
- May 2011
- 40
August 20th, 2015 11:51 PM #2494
sakin din sir same tayo may dribbling sound, taga pateros ako pinaayos ko pa sa jp wheels center sa pnaque dahil nabasa ko wala negative reviews. una akala ko bushing lang estimate mga 1k at yari naging 15k.. pinapalitan ko shock absorber, replacement na shock mount and stabilizer link (sure daw sila 100%) at break pads front at camber alignment.. nawala sandali twice ko lang ginamit bumalik balak ko dalhin sa servitek (update ko).. pero pag rack and pinion problem di ko na papalitan kasi may nabasa ako di naman daw dangerous yun tiisin ko na lang annoying sound
- Sep 2014
- 2
August 21st, 2015 05:41 AM #2495
- Sep 2014
- 2
August 21st, 2015 05:42 AM #2496Hi, I had the same issue so I had my car weighed (2008 1.6G MT) and voila, it only weighs 1,200 KG which is LIGHT. So I had my car registration changed from Medium to Light. You guys should do the same.
- Jul 2015
- 25
August 21st, 2015 09:43 PM #2497Sirs, any recommended shops for tune-ups and repairs for our Altis in Mandaluyong?
August 21st, 2015 11:11 PM #2498
^^ okay lang ba few blocks away from Mandaluyong? SpeedyFix located at 308 P. Guevarra san juan
- Jul 2015
- 25
August 24th, 2015 07:53 PM #2499Thanks, Kimbon. I went there earlier to have my Altis checked. Service is indeed very good.
August 24th, 2015 08:06 PM #2500
Xiaomi E-Car
