Page 207 of 371 FirstFirst ... 107157197203204205206207208209210211217257307 ... LastLast
Results 2,061 to 2,070 of 3706
    Oct 2011
    #2061
    Quote Originally Posted by pchsmvp View Post
    hi mga sir.. okay po ba yung 1.5 A/T na avanza? planning to buy next year.. any suggestions??
    next year ka na kumuha para new look na Avanza mo.
    Aug 2009
    #2062
    Hello po, ano po ang ginagawa sa 40,000 pms? Sabi ng tyt pamp, general job dw po, ano po kaya yung general job na sinasabi?? Di ko po kasi natanong. Di daw makayang matapos ng kalahating araw. TIA
    #2063
    Quote Originally Posted by gianni View Post
    if you are lucky, the car manual might indicate what items are to be checked, replaced, replenished, adjusted, etc, in the 40,000 km check-up.
    many of these, i will confess, i have sinned by omission. but one item you must never omit, is the scheduled replacement of the timing belt. (those who have timing chains, or timing gears, are truly blessed..i am not sure what the avanza has.. belt or chain.)
    Aug 2005
    #2064
    Timing chain for the avanza
    #2065
    that's great!
    Oct 2009
    #2066
    Something to wait AVANZA 2012 (Veloz): The All New Avanza Veloz - YouTube
    Oct 2009
    #2067
    Here's another video for 2012 All New Avanza. SLIDE NEW AVANZA.avi - YouTube
    Super Ganda!!!
    Dec 2011
    #2068
    kelan kaya labas nyan sir? Nag order na kami ng Avanza J sa Toyota Shaw this December
    pero sabi out of stock na ang Avanza 2011 dahil lalabas na raw 2012 Avanza and additional 20k sabi ng bangko
    #2069
    ^pwede nayan 20K additional dahil new look ang avanza2012. bawiin mo nalang sa mga freebies...
    Aug 2009
    #2070
    Done with 40k pms
    Job done:
    Inspected cooling & heating system
    Replaced engine oil
    Replaced engine oil filter
    Inspected engine coolant
    Replaced spark plugs with 3-way catalytic converter
    Replaced air filter
    Inspected fuel tank cap, fuel tanks & connections
    Inspected charcoal canister
    Replaced brake fluid
    Replaced differential gear oil
    Inspected, cleaned, and adjusted brake lining & drums
    Inspected transaxle/ transmission oil for m/t
    Inspected brake pads & discs
    Inspected brake line pipes & hoses
    Inspected steering wheel, linkages & gear box
    Inspected front and rear suspension
    Inspected air conditioning
    Inspected drive belts
    Inspected exhaust pipes & mountings
    Inspected battery
    Replaced fuel filter
    Inspected PVC valves, ventilation hoses & connections
    Inspected brake pedal and parking brakes
    Inspected power steering fluid
    Inspected wheel alignment (4-wheel & 2- wheel)
    Inspected ball joints & dust covers
    Tighten bolts & nuts on chassis & body
    Inspected tires & inflation pressure
    Inspected lights, hirn, wipers & washer
    Riad test
    Cost: 12,075.05
    Duration: 3 hours
    Battery(stock):
    2years & 3 months
    Condition:
    Good
Toyota Avanza Owners & Discussions [continued]
