Results 2,061 to 2,070 of 3706
December 15th, 2011 05:52 PM #2061
- Aug 2009
- 96
December 17th, 2011 10:59 PM #2062Hello po, ano po ang ginagawa sa 40,000 pms? Sabi ng tyt pamp, general job dw po, ano po kaya yung general job na sinasabi?? Di ko po kasi natanong. Di daw makayang matapos ng kalahating araw. TIA
- 54,234
December 17th, 2011 11:12 PM #2063if you are lucky, the car manual might indicate what items are to be checked, replaced, replenished, adjusted, etc, in the 40,000 km check-up.
many of these, i will confess, i have sinned by omission. but one item you must never omit, is the scheduled replacement of the timing belt. (those who have timing chains, or timing gears, are truly blessed..i am not sure what the avanza has.. belt or chain.)
- 54,234
December 21st, 2011 04:01 PM #2066
Something to wait AVANZA 2012 (Veloz): The All New Avanza Veloz - YouTube
December 21st, 2011 06:38 PM #2067
Here's another video for 2012 All New Avanza. SLIDE NEW AVANZA.avi - YouTube
Super Ganda!!!
- Dec 2011
- 75
December 22nd, 2011 05:31 PM #2068^
kelan kaya labas nyan sir? Nag order na kami ng Avanza J sa Toyota Shaw this December
pero sabi out of stock na ang Avanza 2011 dahil lalabas na raw 2012 Avanza and additional 20k sabi ng bangko
December 22nd, 2011 10:49 PM #2069
^pwede nayan 20K additional dahil new look ang avanza2012. bawiin mo nalang sa mga freebies...
- Aug 2009
- 96
December 23rd, 2011 07:44 AM #2070Done with 40k pms
Job done:
Inspected cooling & heating system
Replaced engine oil
Replaced engine oil filter
Inspected engine coolant
Replaced spark plugs with 3-way catalytic converter
Replaced air filter
Inspected fuel tank cap, fuel tanks & connections
Inspected charcoal canister
Replaced brake fluid
Replaced differential gear oil
Inspected, cleaned, and adjusted brake lining & drums
Inspected transaxle/ transmission oil for m/t
Inspected brake pads & discs
Inspected brake line pipes & hoses
Inspected steering wheel, linkages & gear box
Inspected front and rear suspension
Inspected air conditioning
Inspected drive belts
Inspected exhaust pipes & mountings
Inspected battery
Replaced fuel filter
Inspected PVC valves, ventilation hoses & connections
Inspected brake pedal and parking brakes
Inspected power steering fluid
Inspected wheel alignment (4-wheel & 2- wheel)
Inspected ball joints & dust covers
Tighten bolts & nuts on chassis & body
Inspected tires & inflation pressure
Inspected lights, hirn, wipers & washer
Riad test
Cost: 12,075.05
Duration: 3 hours
Battery(stock):
2years & 3 months
Condition:
Good
I use imgur.com. Upload the picture there, then get share links, choose bbcode and paste here.
Mineral , semi synthetic or fully synthetic?
