Page 659 of 749 FirstFirst ... 559609649655656657658659660661662663669709 ... LastLast
Results 13,161 to 13,180 of 14970
    May 2007
    #13161
    Quote Originally Posted by nimbus2000 View Post
    magandang gabi sa lahat
    may tanong lang po ako... mag1month na sa kin ang avanza ko, first car, wala din po ako masyadong alam sa sasakyan. napansin ko lang na 1200-1300rpm sya kahit idle. kahit kakastart lang. may nabasa ako sa thread na okay lang daw lalo kung mejo mainit... pero kasi kahit malamig eh ganun parin
    is there something wrong with my car?
    maraming salamat...
    sir nimbus
    if i am not mistaken the thread mentioned that "if just started", normal lang na mataas (more than 1000). but when it reaches its normal operating temp (Oil Characteistic), it goes below 1000. pag mataas pa rin ang idle mo pag maiinit na makina (usually oil temp indicates half of the indicator), may problema ka sa idle speed. Matalino na kasi ang fuel/oil system natin (VVT-i). You ma refer to CASA na if that is the case. HTH
    (Sa wakas nakapasok din ako sa thread. BTW hindi po na apektuhan si vanzie during the recent calamities. Tried to use kennon going up last time. Not advisable. instead, Take Marcos Hiway in going up to Baguio. Chances are you wont notice the 25-meter road cut)
    May 2007
    #13162
    maraming salamat...
    sir nimbus
    if i am not mistaken the thread mentioned that "if just started", normal lang na mataas (more than 1000). but when it reaches its normal operating temp (Oil Characteistic), it goes below 1000. pag mataas pa rin ang idle mo pag maiinit na makina (usually oil temp indicates half of the indicator), may problema ka sa idle speed. Matalino na kasi ang fuel/oil system natin (VVT-i). You may refer to CASA na if that is the case. HTH
    #13163
    * ma'm nimbus2000:
    kumusta ma'm? recheck ko tommorow ang avanza ko kung exactly same lang ba tayo.
    Dec 2007
    #13164
    maraming salamat...
    Hello po.
    Baka naman po KAPAG bagong start lang dun siya 1200-1300rpm? Ganun din kasi ang Avanza ko. Pero after around 5 minutes or so, bababa na sa 650-800 rpm pag mainit na (halfway na yung Temp gauge).
    Aug 2005
    #13165
    maraming salamat...
    Quote Originally Posted by woohoo View Post
    Hello po.
    As long as bagong start ang makina at hindi pa naaabot ang optimal water temp. mataas talaga ang idling at more than 1,000 RPM. Once na reach na, bababa to less than 1,000 rpm.
    If I am not mistaken, kahat ng kotse na may computer ay ganito ang behavior.
    BTW, pag start ng makina, hindi ko na hinihintay matapos ang warm up period na ito. Alis na kaagad. Iyun lang nga, hindi muna hataw para may time na uminit ang makina at ang oil. Best performance ng oil ay pag na reach na ang operating temp.
    Oct 2007
    #13166
    Confirm mo ulit try mo after usage, idle mo engine, coolant temp mo somewhere 30% to 45%, wag mo pihitin steering wheel, dapat below 1000 rpm lang yan, try mo din patayin A/C kung magbago rpm. Kung ganon padin ganito gawin mo dalin mo nalang sa casa mas alam nila yan
    #13167
    * ma'm nimbus2000:
    Mine,
    1100~1300 Initial start
    900~1000 After 5~10seconds
    600~750 Settled
    No AC on, Front wheel * Straight position.
    We have the same car but mine is with 3k6 mileage.
    Oct 2009
    #13168
    * avanza84, xda2jojo, woohoo, meledson, shadow:
    thanks sa inyong lahat check ko mamaya yung sa car ko. try ko lahat ng sinabi niyo, then post ko ulit dito. napansin ko kasi yung sa sasakyan ng officemate ko, mabilis bumaba yung rpm nya pagkastart, pero strada yung sa kanya. sakin kasi, parang di bumababa ng ganun kabilis, pero nakaON agad ang A/C
    [COLOR="rgb(46, 139, 87)"]* xda2jojo:[/COLOR]
    ok naman, still overwhelmed with our new ride so far so good. 300 km na lang then punta na kami sa casa for the 1st check up
    thanks and more power sa lahat
    #13169
    good pm po, ask ko lng po yung sa odometer ko palaging naka ilaw ang air bag ko, what could be the possible problem? nalubog kc avanza ko sa baha, thanks po!
    #13170
    1st check-up sa 300km, di ba dapat 1000km?
    Sep 2005
    #13171
    nasa 700kms na sya.. so 300kms na lang daw 1T PMS na.
    Sep 2005
    #13172
    pa check mo sa casa.. baka grounded pa din ang wirings.. or baka may tama ang computer box mo.
    Quote Originally Posted by wb_23 View Post
    #13173
    *wb_23
    Pareho tayo ng problem. Sabi ng mga Toyota SA sa akin pag ganyan daw baka daw nasira ang ECU ng airbag, papalitan daw. Nasa Toyota Balintawak na ung avanza ko nong Oct. 30 and up to now di pa nauumpisahang gawin.
    #13174
    thanks Miavanza for the info , maybe i should disconnect it habang hinde ko pa mapa gawa.
    Oct 2009
    #13175
    * xda2jojo:
    yup, 1000 km... naka700 na ko, so 300 more to go
    tama nga... 1250 sya pagstart then bumaba after few minutes... tnx a lot sa inyong lahat... more power
    Quote Originally Posted by xda2jojo View Post
    #13176
    hahaha....mali ang pagkabasa ko....sowe
    May 2008
    #13177
    Quote Originally Posted by Miavanza View Post
    *wb_23
    sir paki pa check mo rin yung ribbon wire mo sa manibela usually sa avanza yan ang nagkakaproblema lalo na pag-napasobra ka ng liko, try nyo rin mag-pa OPD ng computer box
    Oct 2009
    #13178
    Pls help me. I've notice that the avanza 1.3j don't have a console box. Where can i buy it?
    Aug 2005
    #13179
    Quote Originally Posted by Bonsaix View Post
    Marfin has it.
    Sep 2005
    #13180
    makukuha ko na daw sa Friday si Goldie!!! waaaaaaaaa after 1 month and 18 days sa casa!
