Results 1 to 10 of 14
- Jul 2016
- 72
August 10th, 2016 11:32 AM #1Hi those of you owning one is it normal to experience problems with your brakes like parang if nilusong sa baha or nabasa yung break pads nagslide sha ng konti and kailangan pump ng pump para kumapit ulit? It happens to me in the morning kapag hindi nagamit yung kotse or kapag malakas ang ulan. Never ko pa nalulusong sa baha yung unit ko. Thanks I need your inputs on this.
- Apr 2016
- 102
August 10th, 2016 02:06 PM #2
- Jul 2016
- 72
August 10th, 2016 02:20 PM #3Is this normal for you guys? Ang pagbreak ko dahan dahan lang
- Jul 2016
- 72
August 10th, 2016 02:21 PM #4By the way it comes and goes kaya hindi malaman ng taga toyota ang problem. Ang usual na sasabihin nila is that ipump lang ng ipump para matuyo yung sa braking system.
- Oct 2009
- 2,271
August 10th, 2016 03:29 PM #5
- Jul 2016
- 72
August 12th, 2016 03:15 PM #7
If the car gets wet, it may happen. you can also ask the dealer to check and bleed the brakes during the next service stop.
- Aug 2006
- 52
August 13th, 2016 02:26 AM #8there might be air in the brake lines
ask the dealer to bleed it
pumping the breaks is not a good idea
August 13th, 2016 01:17 PM #9
Brakes brad
Pumping the brakes is not bad. It is a hydraulic system after all.
If the disc brake and brake pads are wet the friction is less, this means the bite isnt as good compared to dry surfaces.
How do you dry a baha submerged brake system? Slowly slowdown. If its raining just keep distance.
In the morning there is oxidation on the disc brake surface because of rain or high humidity. Going through your subdivision speed breakers is enough to clean it in my opinion. Slowing down cleans the surfaces.
If the brake drums are submerged then worst case scenerio-it just needs cleaning with steel brush and brake cleaner.Last edited by StockEngine; August 13th, 2016 at 01:21 PM.
- Jul 2016
- 72
August 13th, 2016 04:18 PM #10Thanks for your inputs. Brought it to toyota and the service man told me its called brake groaning. Yes you are right because I encounter this during the morning or when I don't use my vehicle for days. What the service man explained to me that its normal especially for automatic vehicles to experience this and its best to pump in a few so it could warm up a bit.
I would suggest being careful with websites, youtube channels, tiktok accounts, facebook pages,...
Hybrids and EV
