Results 921 to 930 of 1613
- Sep 2011
- 262
May 7th, 2012 09:56 PM #921anyone: nagbabawas ng langis ang engine ng fx ko, siguro mga 3 months after ko maglagay. diesel ito, kelangan ko na ba syang ipa overhaul? thanks in advance
May 18th, 2012 10:54 PM #922
- May 2012
- 1
May 23rd, 2012 03:14 AM #923sira ba idle air control valve ko kapag nakabukas ung aircon mas mababa ung idle rpm nya 500rpm, pero kapag patay ung aircon 1000rpm idle, tapos pag nakabukas ung aircon while turning nag stall ung sasakyan? tamaraw fx 96 gas, sino ba gumagaw nito ung car mechanic or aircon specialist kung papalitan ko sya?
san ba located ung idle air control valve, anyone can post pics and pinpoint it, tia
- May 2012
- 2
May 23rd, 2012 05:41 PM #924newby here fx owner din 94model 7k engine tanong ko lang kung ano mas maganda sa distributor yung electonic ba o contact point yung sakin kasi electronic type,TIA
May 26th, 2012 10:39 PM #925
- May 2012
- 2
May 27th, 2012 03:14 PM #926thanks for the inputs yup orig pa kasama na kasi yung distributor ng binili ko yung makina nagpalit na kasi ako from 5k to 7k kumatok na kasi makina ng 5k ko
- Sep 2010
- 7
May 27th, 2012 04:45 PM #927excuse me po snio good afternoon mga sir, baka matulungan nio ako may maisusuggest po ba kayong mekaniko ng tamaraw fx 96 7k model ni erpat, may mga problem nakasi isa na yung nangangamoy gas pagkakagamit.. yung mapapagkatiwalaang mekaniko po and malapit sa area namin, las piñas area po kmi. salamat po
- Aug 2008
- 51
May 27th, 2012 05:56 PM #928yung adjustment nasa ilalim ng air filter housing, yung may flying saucer na bakal. may nakakabit dun na L-shaped metal na may screw at spring sa dulo. yung screw ang pang-adjust. turn on mo a/c before adjusting using a long screwdriver, turn clockwise.
if namamatay while turning the engine (assuming power steering) may problem sa PS system, baka may bara kaya nahihirapan yung engine magpump ng fluid.
- Aug 2008
- 51
May 27th, 2012 05:57 PM #929yung adjustment nasa ilalim ng air filter housing, yung may flying saucer na bakal. may nakakabit dun na L-shaped metal na may screw at spring sa dulo. yung screw ang pang-adjust. turn on mo a/c before adjusting using a long screwdriver, turn clockwise.
- Sep 2010
- 4
July 3rd, 2012 09:50 PM #930*mr-xtraordinary
mga sir. tanong ko lang.
tamaraw fx diesel
ung sa aircon ng fx ko, pinalitan na kasi ng compressor, expansion valve, na flashing na din..
pero ung psi nya sa low nasa 60-70 parin.
ano pa kaya problema?? ......
anong klaseng flashing ginawa? patingnan mo sa car aircon specialist yan. wag mo tipirin mapapamahal ka lalo pag sa kung sino sino gagawa na hindi kumpleto gamit. kagaya sa fx namin kung ano ano na pinagpapalitan at na flasshing na daw sabi ni erpat pero di pa rin tumino at sabi compressor na daw. pero sabi ko dalhin sa may kompletong gamit at kahit mahal na aircon specialist. ayun napatino at ok pa daw yung compressor! linis lahat evap. at tamang flashing lang daw. eh ilan na gumawa ang di tumino at compressor na ang suspetsa LoLz. ayun napakalamig na at natuwa si erpat.
Xiaomi E-Car
