Results 1,421 to 1,430 of 1613
- Apr 2011
- 198
April 1st, 2015 06:32 PM #1421hello mga katam2
ung fx diesel ko feeling ko abnormal ang init ng makina.pero hangang 3/4lang ung gauge nya.d lumalampas dun tas ung tubig nagbabawas sa reservoir hindi sa radiator konte lang.normal po ba ito?
salamat po sa mga inputs
hello mga katam2
- 52,731
April 2nd, 2015 12:51 AM #1422
- Apr 2011
- 198
April 2nd, 2015 08:20 PM #1423DR d
tnx sa inputs...ano po ba ang dapat ipa check sa mechanic?
DR d
- Apr 2011
- 198
- Nov 2008
- 641
April 6th, 2015 10:25 AM #14251/4 is low, actually lower than normal which is between the 1/4 and 1/2 mark. You're ok with that temp chief. Just maintain your water with correct coolant mixture, and always check your fan clutch and you'll have no worries.
- Mar 2015
- 6
April 6th, 2015 12:17 PM #1426mga sir. we have a 2000 revo dlx 1.8 gas and lately parang humina ung hatak nya. like dati kaya naming umakyat ng antipolo ng 3rd to 4th gear. ngayon 3rd gear na lng hindi na kaya ng 4th. ano po kaya problema? thanks in advance po.
- 52,731
April 6th, 2015 01:59 PM #1427
- 52,731
April 6th, 2015 02:00 PM #1428
- Mar 2015
- 6
April 7th, 2015 04:46 PM #1429thanks dr.d for the reply. dinala ko po sa mekaniko kanina sabi sa kin di daw kelangan tune-up kasi maayos pa ung makina. Ang problrma daw po is ung clutch. dumudulas na daw sya and baka pudpod na daw. ano po ba normal na ppalitan pag ganito problema? ibababa daw ung transmission. tapos ang singil nila sa akin sa service is Php1800. ok na po ba ung service fee na un? thanks
- 52,731
April 7th, 2015 04:51 PM #1430
high idle RPM at engine start
