Results 21 to 25 of 25
- Jun 2005
- 3,774
February 3rd, 2015 11:55 AM #21lahat ng parts ng oto merom marks. try to remove your bumpers. meron din yan. even the outside case of your ecu will have some sort of marking.
pati yung plastic na engine cover. tignan mo sa ilalim. malamang meron din.
mine does.
its not bothering me either. its just plastic.
just a question though, what answer do you expect from them ba?
- 52,731
February 3rd, 2015 03:27 PM #22
February 3rd, 2015 04:45 PM #23
Note that these parts arrive at the assembly plant in container vans and pallets. It's not unusual for checkers, even when an electronic inventory system using RFIDs and barcode readers are being used, to put human-readable notes on hidden surfaces of parts. It doesn't always mean there's a flaw. Sometimes they write this on the first or top-most part of a pile of parts.
Now, if there was indeed a problem with the part during manufacturing and the mark was a symbol for "reject" (ie. paint blemish, over-spray, etc.), it may likely have been re-done. If not, it will show upon inspection.
But try to put things into perspective. The part in the picture where the writings are isn't a critical component. And if it makes you feel any better, you can just do an inspection to validate if there's indeed a hidden problem with it.Last edited by oj88; February 3rd, 2015 at 05:01 PM.
February 3rd, 2015 09:29 PM #24
^Basically that.
Having a simple delivery date on parts in a bin helps ensure that they use earlier batches first and don't mix them up on the line.
And if the marking means there's a defect... that's a bumper. If your theory is correct, then there should be a paint defect on the outside of the X.
Is there? Is it noticeable? From the pictures, it looks like a perfectly straight, perfectly smooth plastic bumper cover, to me. I wouldn't lose any sleep at all over it.
February 8th, 2015 09:34 PM #25
This reminded me of our Fortuner which got flooded by Ondoy. When we got the car back from Toyota Pasig, halos lahat ng panels may markings. These douches marked them with the plate number of the car. Ok sana kung madaling tanggalin kaso ginamit nila permanent marker.
Xiaomi E-Car
