Results 1 to 7 of 7
- May 2008
- 117
October 14th, 2010 03:00 PM #1tried to start up an old big body gli that has been unused for almost a year. put in a new battery but when i turned the ignition key, the dash indicator lights did not even light up and nothing happened. suspect the ignition switch is defective but would like some opinions before i take the thing apart. tia
- Jul 2010
- 166
October 14th, 2010 04:21 PM #2naku sir! tagal di nagamit ah! una nyo pa check wiring, baka inamag na mga connections nyan. tapos saprk plug.
October 14th, 2010 04:38 PM #3
October 14th, 2010 04:51 PM #4
+1 on this.
hindi pwedeng ignition solenoid/switch ang problema mo since nasabi mo na walang indicator na lumabas sa dashboard (gauge) mo when you turned the key to "ON".
while at "ON", try opening your lights, if hindi nag-open (nothing happened), linisin mo contacts (yung kumakapit) sa battery terminals.
kung malinis na ang contact at ganun pa rin, might be nag-corrode na ang wires mo. kung may daga sa inyo baka nangatngat din.
- Jan 2010
- 367
October 14th, 2010 05:31 PM #5
- 52,731
- May 2008
- 117
October 15th, 2010 12:45 PM #7forgot to mention that i also tried to start the gli hooked up to another car using jumper cables with the same results.
thank you for the replies. i listed them all down and will try them out this weekend. hope its something simple because an original ignition switch will costs 4K. WIZZARD said that it might be repairable for around P800.
high idle RPM at engine start
