Results 1 to 10 of 14
March 4th, 2003 10:33 PM #1
is it a part-time 4wd or the full-time 4wd as in other markets? and may diff locks ba siya like in the US version?
wala lang... rode in a friend's LC80 this morning and i didn't see any C/D lock buttons or diff lock switches, and i was a bit surprised na walang center console; the handbrake lever, shifter, and transfer case lever (marked H-N-L-L4?) were sprouting off the carpet on the floor hehe
Tsikot Member Rank 3
- Dec 2002
- 636
March 5th, 2003 07:04 AM #2mbt,
Local version LC80 is part-time 4wd, manual locking hubs and no diff locks. Transfer case with H-N-L only. Basic but does the job.
Anyone with an LC80/100 experiencing a rattling noise from their transmission that disappears when you depress the clutch pedal? Is this a lack of lubrication on the clutch fork mechanism or a release bearing problem? Noise seems louder when the engine is hot.
- Jan 2003
- 106
March 6th, 2003 10:25 PM #5
Parang dressed-up base model ang local release ng LC80 dito so walang fancy 4WD system at center console. Even the seats are similar to base model LC80's.
March 7th, 2003 02:27 AM #6Originally Posted by jackaroo
- Dec 2002
- 636
March 7th, 2003 08:14 PM #7vinj,
Thanks.
Did you have to replace the clutch disc, pressure plate or just the release bearing? Did the noise ever come back with the new release bearing? How many kms travelled when you replaced it?
March 8th, 2003 12:53 PM #8
I'll try to dig up the old casa papers (if i can find them) to check what was replaced. All i remember was the release bearing was the culprit according to my tito (and this was 4 years ago). The noise disappeared and it's still OK till when i drove the car a couple of months back.
From what i remember, the odo was somewhere in the range of around 30-40+ thou km that time. Now, the car only has around 60K on the odo.
From experience (with two LC80's), the achilles heel always seemed to be the clutch. When it's driven hard (i.e. passing then shifting at high RPM's), the stock clutch really takes a beating with the turbo.
- Dec 2002
- 636
March 8th, 2003 09:32 PM #9vinj,
Thanks.
I've complained about the noise since 2 yrs ago and it's only now that the dealer is doing something about it after writing a strong letter to Toyota Phil. They're not absolutely sure it's the release bearing (other possibilities mentioned were pivot bearing on clutch fork, loose damper springs on clutch disc) so they want me to change all the parts, ie, pressure plate, clutch disc, release bearing- all parts for my account!
I've seen the clutch parts they removed and they still look good for another 40Tkm (only done 25Tkm) so i'm asking them to replace the release bearing only. Hope this solves the problem.
On mobil gear oil- Have you ever tried mobil SHC 75w90 synthetic gear oil for diffs, transfer and gear box?
March 9th, 2003 07:45 PM #10
No feedback on trying Mobil for the gearbox and Diff. As long as it fits in or exceeds the recommended specs for the LC then it should do fine and Mobil is considered to be agood brand (this is also my weapon of choice for our rides).
I would also suggest that you change the parts one by one, however the penalty you might get from this is the labor charge for taking down the clucth everytime you do so. Maybe you can try work out a deal with the casa for that. IMO, it is a typical casa mentality to change all the PROBABLE parts without trying first to get it on a step-by-stepo basis.
You could also go get a second opinion on the clutch from another shop. Try Kartek in SanJuan (Santolan rd., near Ortigas/Pasadena). The service manager there used to work with Toyota Shaw (as well as some of the mechanics) so he knows some good bits on Toyotas (mahal lang yung parts nila so i usually source my parts from outside).
high idle RPM at engine start
