Results 1 to 6 of 6
- Jul 2010
- 166
December 12th, 2011 03:38 PM #1magtatanong lang po, maganda po ba yung sparkplug na bosch platinum? pwede po ba to sa corolla bigbody 2e engine?
December 12th, 2011 06:05 PM #2
Seems okay although i'd still stick with either NGK or Denso for Toyotas. Just make sure you have the proper plug model, gap and heat range for your car and all should be fine.
December 12th, 2011 10:48 PM #4
Japan engine must use a japan spark plug like NGK
eto gamit sa 2E ko NGK platinum
- Jul 2010
- 166
December 13th, 2011 01:56 PM #5naikabit ko na po yung bosch platinum, ano po sa tingin nyo? magkakaproblema po kaya ako? masisira po ba makina ko?
December 14th, 2011 09:03 AM #6
high idle RPM at engine start
