Results 1 to 6 of 6
    Jul 2010
    magtatanong lang po, maganda po ba yung sparkplug na bosch platinum? pwede po ba to sa corolla bigbody 2e engine?
    Seems okay although i'd still stick with either NGK or Denso for Toyotas. Just make sure you have the proper plug model, gap and heat range for your car and all should be fine.
    Oct 2009
    denso plugs gamit ko now para walang problema.
    Japan engine must use a japan spark plug like NGK
    eto gamit sa 2E ko NGK platinum
    Jul 2010
    naikabit ko na po yung bosch platinum, ano po sa tingin nyo? magkakaproblema po kaya ako? masisira po ba makina ko?
    Quote Originally Posted by devond View Post
    As long as walang tope and your car runs fine, it should not cause you any problems.
sparkplug
