Hello everyone! A friend of mine introduced me to this forum
and have read with interest some of the topics posted here.
I have some concerns with my 1995 Corolla GLi (4AFE engine,
16 valve - stock) as my friend could not answer all my questions.
I am hoping for some help, guys.
1. Idling seems to be okay when the A/C is turned on. However,
it goes down to around 750 (i believe) and the engine "nangingingig"
ng konti (but not to the point na it will die down. It then returns
to around 900-1000 RPM when A/C "engages". Is this normal?
2. When A/C is off, idling (RPM) is around 750 (according to
the results from an analyzer used at Servitek) - nanginginig
ng konti ang makina - but di naman namamatay. Is this normal?
3. After starting the car, I turn on the A/C, then drive. Ok naman
ang lamig (nasa 1 setting lang ako parati). However, I noticed
na pag natrapik ako, full stop, blower na lang ang nararamdaman
ko (wala na yung lamig).
Di na rin nag-auautomatic yung A/C. I tried putting the A/C setting
into 2, 3, and 4 - kaso ganun pa rin.
Babalik na lang to normal operation yung A/C pag tumatakbo na uli
ang car.
What could be the problem, guys? Please help!
This is my first post, nga pala. Sana may makatulong sa akin.
Thank you, fellow Tsikot members!
P.S.
Less than 4 weeks ago, I had my coolant, brake fluid, and
power steering replaced. I also replaced all my spark plugs
and air filter, as well as changed my engine oil, fuel filter, and oil filter.
I have also just used the Mitsubishi Fuel System Cleaner -
dito ko nabasa at natutunan yun
I have also just purchased a set of new tires for it.
Except for the above-mentioned concerns, maayos ang
takbo ng car - matipid (9-10 km city driving) - malakas ang hatak
at matulin. And never siya nag-overheat.
Thank you, fellow Tsikot members for your help!
. Magaspang ang makina during idling with the aircon on, pero makinis ang takbo kung walang aircon or when the car is in motion. I felt this 2 years ago. I already replaced my engine supports and changed my compressor last year. Last week, my evaporator gave up and was replaced with original denso evaporator
. A mechanic told me to have the servo cleaned because it is related to the aircon. However, a mechanic in the Alabang Motortown did not agree that the servo was the problem since the di naman daw nahihirapan ang makina, although nanginginig nga. He fixed the timing but later gave up and did not find anything wrong with my engine
. When I have time, I will have the servo and the fuel injection cleaned in a different shop.
