Results 31 to 40 of 1628
- Oct 2005
- 123
April 19th, 2007 10:08 PM #31Please refer to the manual for the purpose of identifying similar subject matter. As of the cause, I just went to marikina branch this morning to have my EGR - Exhaust Gas Recirculation valve replaced. It is somewhere (like a joint) near the 'camber (as the technician called it) of our Turbo. Naipon nung mga carbon dun kaya nadedetect ung corresponding sensor.
The chief technician also gave me a tip that such error or warning may be ignored and can be even reset (for EFI systems) by detaching the negative part of the battery. In this way, your car electronic system can be reset and if it is true that such warning were turned on incidentally, then it will not turn on anymore after reseting your system. However, if it will persist, then you better consult with your nearest toyota (after consulting of course you manual first).
More so, such EGR valve will cost around php 8,500.
- Feb 2007
- 128
April 20th, 2007 07:22 AM #32sa sir bakit di nila reneset yung system mo? bakit they replace the EGR? under warranty pa ba yan?
Bongliza sir, Innova ba yan? thanks
April 20th, 2007 09:28 AM #33
Bro, Sorry to hear that Bong. I think you are third owner of D4d here in tsikot having twice of the problem. May I suggest that you request to REPROGRAM your ECU first before they replace again your CRDi system. It is faster and easier. Anyway nothing to loose it is very cheap and it is covered under warranty.
Tsikot Member Rank 3
- Sep 2003
- 786
- Apr 2007
- 12
April 27th, 2007 01:36 AM #35hello everyone,
i'm planning to buy an innova j m/t gas around the end of may. im from cebu city and i don't have an idea where to get the best deals around. could someone please help?
- Mar 2007
- 239
April 27th, 2007 07:10 PM #36mine is innova G d4d mt Feb. 2006 and already >16,000 on the odometer but thanks God no problem like hard starting, leaking shocks, etc except can't go beyond 8.8 km/l city driving.
- Oct 2006
- 114
April 30th, 2007 05:34 PM #37it sounds unfair to us buyers but to me, it's wise NOT to purchase newly introduced cars/technology. like the personal computers, they always have bugs. so if you can wait for the next batch the better or purchase an old model but reliable one.
i remember when forts & innovas were introduced, i told my officemates not to buy YET cause they might end up scratching their heads...
- Sep 2004
- 38
May 1st, 2007 03:02 AM #38hi guys, would it matter what brand of diesel to use? Petron, Caltex, Shell, others? to prevent clogging of fuel filter, or put oil additives? thanks in advance.
Toyota is my choice
- Aug 2005
- 2,063
May 1st, 2007 10:45 AM #39
May 1st, 2007 02:44 PM #40
high idle RPM at engine start
