Toyota's 2 2 Land Cruiser tears into the UAE – here's a look at the brand new model - The National
kaunti lang binago... still my dream SUV..
Sent from my YAL-L21 using Tapatalk
they may release an all new LC 300 in 2021.
and no more V8 engines in favor of twin turbo v6
Toyota LandCruiser 3 Series at least two years away | CarAdvice
Hi Guys. I have a 2018 local LC200 and I notice that sometimes the front aircon vents won't blow air. This is usually the case when I switch to different A/C modes (air flow direction). I have to stop the car and turn the ignition on and off to make the A/C work again properly. It's all the front vents that's being affected and now I feel like my airflow is not as strong as it used to be.
Anyone else have the same issue with their A/C?
Thanks.
Wow. I literally had that same problem yesterday and brought my LC200 to toyota makati today. They 'reset' d aircon controller and its back to normal. Free of charge.
Or you may have to replace the aircon filter.
I did that before and it cleared up. But this time, the air was literally not coming out so i sent it to toyota.
My aircon is fixed again. Yay. Coupled with the new ecu tune and this beast is humming .
Tips on aircon (it happened to both my LC200s)
1. Change aircon filter...usually does the trick
2. Disconnect battery reboot (exactly what Travajente adviced which is what Toyota did and it worked)
Nice ECU tune..
BTW, is your LC have that fancy start button or still using key fob to start?
i noticed that some systems that initialize during ignition ON gets interrupted when we start the car immediately (start button). that is why turn the ignition ON, wait a few seconds for all the settings to initialize (hear aircon flaps moving) , press the brake then start the engine
Yes it has the push start button ignition system.
Thanks guys. I disconnected the negative cable on the battery already for a few minutes. Is there anything else I should do for the resetting?
Air comes out now but I feel airflow is not as strong as it used to be. I have to put the setting to atleast 3 bars to appreciate the AC. Maybe time to change the cabin airfllter? Never changed it (only cleaned) with now 11t km on the odo.
Change the aircon filter. Trust me. Will work.
Hello LC200 owners!
I'm considering acquiring a used LC200 with the intention of having it bulletproofed but am not sure which level of protection is right for me. I'm a businessman and I intend to use it as my daily driver. I see a number of level 6 LC200's in the second hand market but I'm still not sure if it is for me as I see my need for an armored vehicle to be short (maybe 2 years max), I intend to use and keep the vehicle for around 10 years. I saw BR4 level protection available that are light weight, which I read only provide protection against mostly hand guns.
I therefore have the following questions:
1) Which year model and variant is best to consider (2015,2016, 2017)?
2) Best place to look for best price/deal?
3) For those who have experience with using bulletproof vehicles, is BR4 level protection good enough?
4) Are these light armoring materials really effective as per the protection level they claim?
5) Can you recommend a reputable armoring company that is certified?
Thank you for those who would reply.
I'm following this chap... have a look see. Make sure the suspension and brakes are upgraded as well as the wheels.
Hi-Protect Armored Cars Corporation-Carlo Ilusorio - Home | Facebook
