Page 17 of 19 FirstFirst ... 713141516171819 LastLast
Results 321 to 340 of 427
    Thanks i was too lazy to find the power to weight ratio hehe.
    And most people dont understand that the quoted 600NM of torque is just peak torque. Those numbers fall off sharply for vast majority of diesels after 3k rpm (or even less). And the amount that it falls is just as important as the peak number. That will give you an idea of the driveability under full throttle conditions.
    That 600nm is great for pulling or getting yourself out of sticky/steep/rocky situations. It will shine there.
    But it loses puff quickly.
    Sent from my SM-N950F using Tapatalk Pro
    Yes exactly. The LC200 is more akin to a locomotive/bulldozer. It will give you relentless torque at low revs and low speeds to haul or traverse over anything. But if you need to accelerate quickly, it doesn't have the top end that you get from more athletic turbodiesels like in the Tucson CRDi or X3 20d.
    Closest affordable car I can compare it to would be the Everest/Ranger 3.2. You'd think a 200 hp 5-cylinder diesel would be a speed demon but it's really designed to haul heavy loads rather go for outright speed.
    May 2017
    Thanks mga sirs for the education. Another day of learning in tsikot!
    It is a heavy car and the torque arrives in a very small window. Higher rpms it just drops off like a stone. Overtaking at 60 kph on full throttle you feel the lack of power. This happens to me a lot in Morong going to/from Anvaya cove. Nice roads there but overtaking is a PITA with the LC200 due to the power:weight ratio. Really have to tune it. The difference is very noticeable.
    Have driven the LC200 all over Albay. You'd think a 4.5L V8 is ultra-powerful but in reality it suffers from the same lack of top end and sluggishness of all heavy diesels. It does weigh 2,650 kg after all...
    Power to weight ratio is just 87 hp/ton. The 2.4L Montero makes 93 hp/ton.
    Oh wow so heavy nga.hehe Parang biglang lumiit tingin ko sa 600NM published torque. I envy you sir jut! Parang you get to drive lots of cars/SUV's. And not just test drives... real road trips pa.hehe
    I was able to traverse Tagaytay roads once with a friend who owns an LC200 and the steep inclines didnt seem to bother him going up kaya I had an impression that it's got lots of torque/power in real use. But as you said, may small window for the peak torque to kick in nga so i guess overtaking would be a different story.
    Quote Originally Posted by Shutterbug View Post
    Nagkataon lang bro that I get to drive different cars.
    The LC200 really makes easy work of steep inclines. It's got very good torque from the moment boost kicks in until about 3500 rpm. It really feels effortless no matter how steep the incline is. But because it's heavy, it doesn't accelerate as quickly as it feels.
    Torque is the feeling of getting pushed to your seat. But even with that torquey feel it doesn't mean it goes very fast, and vice versa. My Civic for example feels nowhere as torquey as most diesels but can accelerate faster to 100 kph than most of them.
    Mar 2013
    Does zix own speedworks?
    351 ft-lb (475NM) baseline dyno, bitin talaga sa bigat ni LC.
    Why I installed throttle controller? Night and day difference ng naka power mode , with and without throttle controller.
    Regarding sa ecu remapping ng 1vd, hindi na siya masyado mausok, useless na damihan pa supply ng fuel, wala na din gain sa dyno, so balanced lang siya.
    After ecu remapping,
    462 ft-lb (626NM) wheel torque,
    Sakto na sa weight niya [emoji4]
    Mar 2013
    Quote Originally Posted by zix888 View Post
    Very nice. I wonder how it will affect longevity? Thats why i kept my other LC stock. Do you have a dyno? Will dyno my chipped LC200 just to see how much it makes.
    If your ecu programming is better and with less smoke i will switch to that.
    I had my dyno runs at Scag automotive services.
    I have tried different tuning chips before on other vehicles, gain is not as much as ecu remapping.
    That’s why all my units now are ecu tuned.
    also thinking if paparemap ko lc200 ko din dahil baka magkaroon ng problema sa makina in the long run.
    Had my NP300 remap kay speedworks and I am very very happy with the performance. Mas gusto ko gamitin sa lc kasi mas responsive, regarding black smoke meron konti lang pag diniinan ng bigla.
    Jan 2008
    I just bought a 2018 lc200 local and I don’t like the head unit, is there any shops that sells head units same in lc200 dubai version?
    May 2011
    I had the chance to drive a 2012 dubai version LC. Medyo mabigat nga sa sudden acceleration mas ramdam ko pa sipa ng gen 2 montero ko but gradual build up ng speed ang LC, sisiw ang pass 200 kph [emoji23].
    Dubai and local LC same ba aircon system? Because when we had the Dubai LC version last summer kahit tirik yung araw waiting at the parking grabe lamig ng aircon. Umuusok yung hangin lumalabas sa blower sa sobra lamig.
    Sent from my SM-G930F using Tapatalk
    Mar 2013
    Who did your ecu remapping? Speedworks?
    Speedworks
    Mar 2013
    Navgo Electronics - Digital Instrument Cluster Upgarde
    Ordering this for my LC200 as an upgrade.
    Feb 2007
    Very nice ah! Responsive sa video and looks cool with the console upgrade din! Which country sila nakabase? How much un damage if you don't mind me asking?
    Mar 2013
    Am still waiting for the quote. Will send more details as i get
    Mar 2013
    Lots in aliexpress
    Different versions capabilities and functions.
    Jan 2008
    Lots in aliexpress
    Plug and play? No wiring modifications?
    Mar 2004
    Get a Tesla interface for the LC200 ...
    Jan 2008
    .....about to replace the stock head unit with Growl 10 inch head unit.
    Feb 2019
    Hello...I would like to replace the stock Headunit of my LC200 also I'm planning to have it install a 360 surround view camera. guys do you have any recommendations which head unit brand (that can integrate both)and reputable shops that can handle the job?
    thank you!
Land Cruiser LC200
