Results 1 to 8 of 8
Threaded View
November 27th, 2012 08:44 PM #7
when you check the timing belt for synchronization, use the belt timing mark on the crankshaft timing belt pulley itself. toyota harmonic balancers have been known to have spun around the hub making the timing mark unreliable. if it indeed had spun, make a new timing mark on the outer ring of the harmonic balancer as the true and corrected mark
Better to buy the similar-era clone starex 4x4 (not sure lang if local or imported but original lhd...
Mitsubishi Philippines
