Results 1 to 10 of 11
- Mar 2004
- 652
December 18th, 2010 10:37 PM #2
- May 2009
- 7
January 5th, 2011 10:35 PM #3hello mga sir.....newbie lang po ako pag dating sa car...i have a 1996 GLI 1.6.....may problem po yung both rear window ng car ko....nabubuksan naman po sya pero hirap po pag isasara na....any idea po pano ayusin at magkano magagastos ko?....thanks po in advance and happy new year to all...
- Nov 2009
- 456
January 5th, 2011 11:19 PM #4
- May 2009
- 7
January 6th, 2011 10:33 PM #5thanks sir sa reply.....tamang tama gilmore lang ako work....puntahan ko yun....any idea sir how much pacheck up?...
- Mar 2004
- 652
January 7th, 2011 11:06 AM #6if you are by nature a sort of tinkerer, madali lang ito palitan. Punta ka sa banawe or evangelista, pasay. ask ka doon sa surplusan, sabihin mo kelangan mo ng power window mechanism sa corolla big body. pang likod na window, left and right. mga 350 php siguro isa nito.
I changed mine (yung sa driver side at isa sa likod). It's just as simple as ABC.
- Nov 2009
- 456
January 7th, 2011 12:25 PM #7
- May 2009
- 7
- Jan 2011
- 26
January 15th, 2011 10:26 AM #9boss ako din yan din problema ko sa gli ko yung sa likod lang ang umaangat yung sa front ayaw,pinacheck kopo yung sa akin mga 1.5k daw kung 350 each so 800 pala labor?
- Mar 2004
- 652
January 16th, 2011 07:55 PM #10As I have mentioned before, if you are a tinkerer by nature, madali lang iyan. Ang sa harap, cable type ang power window mechanism. ang sa likod, gear type. Bili ka lang sa surplusan (I got mine from Evangelista, pasay), sabihin mo lang harap o likod, kaliwa o kanan.
Tapos, just remove the screws sa covering panel ng pintu-an (mga 2 lang, isa yung sa door opener latch, isa yung sa parang ash tray). then pull out sa ibaba ang cover (clip types lang ang mga ito), then push it up to remove at presto, makikita mo na ang power window mechanism. tanda-an mo lang ang position, 4 screws lang naman ang humahawak nito ( 10 mm box wrench). ang cable connection niyan, clip lang. just press and pull out.
Mileage varies with LED bulbs on multi-reflectors. On the 1st gen Innova with the last facelift,...
2013 Mitsubishi Mirage
