Results 31 to 40 of 48
September 21st, 2005 08:09 PM #31Originally Posted by konde
1st : check coolant level, then all hoses & radiator for leakage - run idle in your garage and look below for water drips. Replace leaking hoses or worn clamps.
2nd : check/replace thermostat - located inside the top hose connection at engine end from the radiator (needs to unscrew 2 bolts to access). - this is the usual culprit = needs few effort & small cost of a new thermostat replacement.
3rd : if still over heating, check/ re-oil your radiator fan - needs 4 tubes of silicon oil to do this.
4th : if still over heating, overhaul or replace your radiator
The above are most common senario on surfs. However, after exhausting the above solutions and overheating still remains, consider causes such as tune-up problems or engine mechanical problems (unusual, otherwise it will not come out of subic).
Other tips I got once you take your vehicle from Subic are
- change oil & filter immediately
- detach rubber tubing to EGR (don't know why though)
- check hair line cracks on the tires (replace with new ones if there are)
- although a lot uses reshaped pitman arm, incase your pitman arm was welded, check quality of the weld (pick it with hammer, look for cracks).
- check tightness of bolts & nuts used on the conversion (idle arm, pitman arm, steering shaft supports and joints)
- remove the front chairs & front carpet. Clean all rubbish/dirt generated during conversion, then apply tire black (to avoid corrosion) before putting back you carpet.
- if the wipers were transfered, apply grease at the underside of the plugged holes (previous positions of wipers) to avoid corrossion.
The above are really tigious to most people. But once you did, it may give you peace of mind to enjoy your vehicle.
However, I also agree on the setting away any dilemna on buying 2nd hand cars, by buying brand new ones (which I also did before). It always depend on our likes & budgets.
September 22nd, 2005 09:50 AM #32Originally Posted by alromcc
September 22nd, 2005 06:56 PM #33Originally Posted by telulah
I for one, was not scared to do all the checks that i should. Also it did not scare me during my long trips from Cavite to Olongapo, and going up to Baguio two times (via rough Kennon road) with my family (5 persons & fully packed with baggage, and AC was on). Till now it is fresh & ready for more adventures. hehehe
Teka, kakahiya na, kasi para na akong salesman e. hehehe
Hanggang dito na lang ang share ko.
Hoped it helped some interested persons. Bye!
- Aug 2005
- 30
September 27th, 2005 10:38 AM #34hahaha. my bro has a subic pajero. Ayos na ayos. enjoy sya. check ni joseph ang conversion at wirings, wala ng pinagkaiba. advantage over the local, mas matulin, (i dont know kung bakit e pareho lang makina,4m40, mas makapal kaha(kaya mas tumatagal kesa local), over all, mas matibay talaga ang galing japan kesa local. Syempre second hand car yon, expected na ang mga dapat gawin pagkabili.
- Aug 2005
- 35
September 27th, 2005 11:56 AM #35agree ako kay rheas. in general, lahat ng ginawa ng hapon for their own consumption is much better and cheaper than the one for export . this is one of their economic strategy. matibay at mura para sa sarili at mahal at shorter life span para sa iba. siyempre depende rin sa competition abroad. kaya dito sa pinas we used to be 5 years behind sa modelo ng japan until tumindi ang competition .
we just have to be very carefull with the conversion. this is where jga22bo come in and streamline all the commercialized conversion. these are facts and not a paid ad by joseph
- Aug 2005
- 30
September 27th, 2005 04:48 PM #36Ilalaban ko nga ng pokpokan ang pajero ng utol ko sa local e kung patibayan din lang ang pag uusapan. Minsan pinagsabay namin ang local na fieldmaster at exceed sa coastal, e talagang iba humataw ang exceed. e sa tingin nalang mas mukha pang mabigat ang exceed kesa sa local fieldmaster. ewan ko lang kung talagang me kaibahan ha. ako me hawak ng exceed sya sa fieldmaster. Nung sumunod na test palit kmi kse bka sa driving nagkatalo e ganun parin at pareho kmi ng pakiramdam sa kanya. Ang tingin ko yung ibang me ayaw at galit sa japan imports e di matanggap na mura lang ang mga ito against sa mahal nilang pagkakabili sa local, at the same time e mas matibay pa kung tutuusin. Just my observation. Peace sisters.
September 28th, 2005 09:52 AM #37
rheas-
it is not fair to judge those who are against it by saying they are jealous, whatever reasons they have against subic cars should be respected also by those who are open to subic cars.
fair comment ba ito? it is not the job for those who own subic cars to compel those who do not to share your point of view by saying they are jealous, on the contrary, what they are after is peace of mind, we on the other hand, are willing to risk it.
September 28th, 2005 11:58 AM #38Originally Posted by telulah
September 28th, 2005 01:04 PM #39Originally Posted by RedHotBlood
September 28th, 2005 05:24 PM #40
you're right telulah, very powerful yung engine na yun ang gaang ng pedal at lakas ng hatak. Too bad nga lang yung parts sa engine hirap hanapin, pero di ko alam na may surf na ganito engine. Ok pa naman yung surf pero di ko na try ng matagal sa kuya ko kasi yun. Again, he has no problem with it.
Somewhat expected from a rushed car from a first time carmaker
Xiaomi E-Car
