Results 11 to 18 of 18
June 23rd, 2006 09:52 PM #11
pwede pala pa-order ng parts sa subic! sayang...layo lang... hanap kaya ko ng ready 3c-te w/ computerbox dun pag may time...
June 23rd, 2006 09:54 PM #12
about sa code mo sir rion: ung 2c-te ko daming hoses e nabunot din...deym, baka mali kabit ko..pero i doubt, may length difference naman,e..
June 24th, 2006 12:13 AM #13Originally Posted by alwayz_yummy
as for mine, it was a real disaster. boost valve that needs an air push was getting an air pull instead. though we have lot's of townace displayed in our shop to refer, but they are different from ours . infact I do get confused with Japan surplus because they all looked different from each other. a 2c-t might not look like the same 2c-t next year.
anyways, I found on the net this "Wouter's page : Land-Rover Engine Choice"
http://retro.co.za/lr/tech/engines.html
he suggested 2 or 3C-T, 2L-T for a Land-Rover. the page also has some engine power specs info.
http://locost7.info/converter.php for Unit Converting (HP,lbf·ft,KW,Kgf·m,Nm etc,..)
btw, sir Yum, is your 2c-te have an intercooler turbo and airscope? 2c-te engine is quite rare.
June 24th, 2006 01:11 AM #14
nope, water and oil-cooled electronic-controlled turbo (di siya nag-boboost kung naka stop (p or n) the todo ko ung rpm.....madaming mekaniko nagugulat, lalo na ung familiar sa 2c-t na pinapalit sa fx....
one time nga nung nagpagawa ako, 2 kaming jdm liteace dun parehong 4wd, fxv ung akin, gxl ung kanya...sa interior palang, lamang na ako... pero surprising kasi, di kami pareho pagdating sa engine bay..maspuno at cramped ung akin..hirap nga magstencil ng motor #...kaya di ito agad magsstart ng engine if its not cool enough...
so i suspect 2c-te ang mga fxv grade (top-of-the line)...mixed siya ng ecu controlled mechanical system...hoses and sensors...mahrap magsabi ng malaking sira,e un pala, sensor lang...
June 24th, 2006 01:30 AM #15Originally Posted by alwayz_yummy
June 24th, 2006 08:35 AM #16
actually, you cannot tell na the difference pag katay na...its identical to any 2c-t but may konting differences, including dapat may ecu yan..pero di na nila sinsama,e...pero once nasa fx na, bypass na lahat ng engine management...
may diagnostics port nga din pala liteace ko..madali sana magtrouble shoot, pero wala me software and equiptment na alama meron for this..
December 25th, 2006 01:08 AM #17
question lang guys, ano ang stock engine ng diesel fed na tamaraw fx?
we have a gas fed FX. 1.5L lang ata ito. sobrang lakas sa gas at mabagal pa. we (office) hardly use it anymore kasi malakas sa gas. and madalas nalang gamitin e hilander kasi mas matipid. nagagamit lang FX pang coding. sayang naman. would it be advisable to swap it to a diesel engine? kung 20-30K ang 2c-t, mag kano aabutin sa labor and other services pa?
December 25th, 2006 01:59 AM #18
Better if you just sell it and add the extra money to buy a diesel version. Mga 50k+ ang conversion (guess-timate... depends on the cost of the engine...) at di ka pa sigurado kung gagana...
Whereas, if you just sell and buy another diesel AUV, you can test-drive and inspect the unit you will buy to replace it. Mas sigurado.
high idle RPM at engine start
