Results 11 to 20 of 30
March 4th, 2011 08:32 PM #11
Kasya kaya 4AGE blacktop sa Lite-Ace para engine swap na lang? hehehe
:massbounce:
- Jan 2008
- 4,726
March 4th, 2011 09:19 PM #13baka need lang ng tune up baka kasi kapos sa gasolina during climb... yung suzuki van ko 3cylinders 660cc engine kayang kaya pumanik sa tagaytay highlands at kahit saan na matarik na parking.. take note 3 cylinder 660cc lang makina nyan eh konti lang ang laki ng lite ace sa multicab
- Jul 2009
- 28
March 4th, 2011 10:22 PM #14Sir, na-curious ako dito ah. Kase ang alam ko low speed ang alam ng mga lite ace owners sa sasakyan namin.
O baka naman relatively comparing sa ride nyo, mas lower speed pa yung sa inyo.
Pero alam ko, compared sa toyota sedans, mas lower speed and lite ace.
Meaning, umiiyak na ang makina sa 5th gear, di pa nakaabot sa 100kph.
March 4th, 2011 10:28 PM #15
- Jan 2008
- 4,726
March 4th, 2011 11:58 PM #17
Hi Firelady,
97' model liteace owner here. I've tried climbing fully loaded sa tagaytay at di nman hirap. Nasa pagaalaga at condition ng makina rin kce.. (IMO)
here are the things i do to make sure ok ang condition ng engine ko:
1. Change oil every 5k miles (sometimes before mag 5k or pwede din every 3months)
2. Make sure carburator ay well maintained ( every 5k-10k miles linis nung akin)
3. Make sure Fuel and air filter ay malinis (kung kailangan ng palitan palitan)
4. I used titanium spark plugs and high tension wires
5. Every 6 or 12 months radiator overhaul maintenance (for me)
Ilan lang yan sa mga maintenance check list ko to make sure na ok ang takbo ng ride ko
for more info join ka rin dito:
http://liteaceclub.com/
- Mar 2011
- 2
March 5th, 2011 10:54 PM #18Guys, maraming-maraming salamat. I appreciate your comments and suggestions. Try ko po suggestions niyo. Observe ko...
Actually, mas enjoy ko gamitin ang liteace kesa kotse. bukod sa kita mo lahat pag nagda-drive ka, masarap din pag passenger ka lang na nakaupo sa likod. i feel relaxed. naitataas mga paa eh. hehe.
Try ko mga sinabi niyo then i'll let you know pag ok na. Again, thank you!!!
March 14th, 2011 10:05 PM #19
kayang kaya 'yan ng well-maintained liteace. i've done very steep inclines with a full load. once, it was steep enough for my friend's vios e to slip occasionally (yup, vios is fwd, but it's that steep). if you've driven to palm beach in bo. hugom batangas, after bo. laiya, then you know what i mean. i guess the 185/70-13 tires helped.
March 15th, 2011 04:46 PM #20
kaya iyan basta well maintained. pero malamang may fault na rin ang sliding clutch sigurado. but aside from that..
my suggestions would be a full tune up.
change oil
spark plugs
fuel filter
clean carb
change carb air filter
Thread was made nung 2018 pa po sir.
