Results 1 to 10 of 30
- Mar 2011
- 2
March 4th, 2011 02:07 PM #1Hello everyone! I'm just new here. I need help...
We just recently bought toyota liteace 1991. ang problema ay hirap itong umakyat pag matarik? what seems to be the problem? anong dapat gawin?
Hope to hear some solutions/responses from you guys. Maraming salamat! God bless.
March 4th, 2011 02:36 PM #2
probably sliding clutch, have it checked.
kapag ito nga ang makita, kailangan palitan ang clutch disc, clutch plate and release bearing. more or less P4k ang magagasta using japan replacement brand; more or less P10k kapag oem ang ikakabit.
March 4th, 2011 02:52 PM #3
have the gear oil checked too.
papalitan mo na rin kapag kulay kalawang na gear oil ng liteace mo.
mga 3 to 4 liters siguro laman nyan. available sa mga gas stations with service bays yan.
goodluck and welcome to tsikot.com!
- Jul 2009
- 28
March 4th, 2011 04:16 PM #5Hi firelady,
May lite ace din family ko.
Ano ba driving conditions? Kargado at naka aircon ba?
Mahihirapan talaga yan pag masyado matarik.
Lumalakas ba hatak pag pinatay aircon?
Kung clutch problem, dapat pansin mo din yan kahit hindi paakyat.
Nararamdaman din yan sa mga biglang arangkada.
I-suggest, have the engine completely tuned up first.
Kung di nyo pa nagawa to.
Spark plugs, distributor, karburador.
You'll be surprised ang laki ng epekto sa hatak pag mali ang "advance" setting sa distributor.
- Jun 2008
- 1,741
March 4th, 2011 04:38 PM #6hirap talaga sa akyatan yang lite-ace.
Personal ko nakita na ang isang brand new Lite-ace kailangan nyang magbwelo mula sa dulo ng drive way para lang maka akyat sa matarik na basement parking. Driver lang ang sakay nyan. Paano pa kung puno ng sakay. Marami rin ang tirik/overheat problem dati. Sablay ang toyota sa van na ito.
Yes tune up muna then maybe clutch overhaul.
March 4th, 2011 04:50 PM #7
How steep is the hill?
Our 2.0 Vanette couldn't climb some hills in Tagaytay without a running start... even some steep city parking ramps had to be taken at full tilt in first gear...
The Liteace is worse in every way... except, perhaps, in fuel economy... still... don't expect much from a carbureted 1.6 liter van, especially with a full load.
- Jul 2009
- 28
March 4th, 2011 06:35 PM #8Di na natin alam kung ano HP ng 1.5L na 5K engine ngayong luma na to, pero I'm sure talo to ng 1.3 Avanza engine
Ganito gawin mo firelady -
Cruising at 50-60kph at 4th gear, dapat maakyat mo ang matataas na flyover without shifting back to 3rd. Pag nabitin, kelangan ng tune up nyan. Medyo low speed ang tranny ng lite ace.
Ako pag dala ko lite ace, di ako nagpapark sa mataas na bldg parking ng malls, unless yung na try ko na. Sa open parking lang lagi, tiis sa init.
Pero na try ko na ang Tagaytay Highlinds once, dalawa lang kami, at di ko na uulitin kahit kailan hahah. Pero kaya talaga pag nasa kondisyon.
March 4th, 2011 06:52 PM #9
Lite Ace is Underpowered. Hirap na nga sa flat roads, pano pa kaya sa akyatan
March 4th, 2011 08:27 PM #10
High speed ang differential ng Liteace kaya mahina sa akyatan na matarik kung gusto mo talagang lumakas ang hatak sa arangkada at akyatan palitan mo ng low speed na differential o gearing nito . Iyon ang pagkakaalam ko sa lite ace itong makina ko na 5K na Toyota Low speed ang differential kahit puno o sobra pa malakas sa arangkada at akyatan ginagamit ko itong pang deliver ng mga goods na mabibigat.
