Results 11 to 16 of 16
January 21st, 2016 06:50 AM #11
There are about six drain holes in the cylinder head. If these are partially clogged, the oil that went up to the camshaft is not draining back fast enough back to the oil pan with the engine running. Check for sludge build up under the valve cover.
- Jun 2008
- 1,741
January 21st, 2016 09:59 PM #12
- Aug 2015
- 862
- Aug 2013
- 475
January 22nd, 2016 12:41 PM #14kasi bro, kapag umaandar ang makina, kasabay yung pag ikot ng oil pump.
yung oil pump, humihigop ng oil sa oil pan/reservoir.
kaya kung nag check ka ng oil dip stick habang umaandar ang makina, good sign kung walang reading sa dip stick. kasi nag cicirculate ng mabuti yung oil sa engine.
kasi kung may traces ng oil sa dip stick o kung may tumatalsik, ibig sabihin, mataas na yung blow-by gases na nakaka lusot sa half block (mechanics term - piston rings, bearings, clearances ng internals) or sirang PCV valve o low pressure na ang system.
- Jun 2008
- 1,741
June 21st, 2016 11:40 AM #15Ah ganun ba dapat walang level sa dip stick pag umaandar😉
Sent from my Lenovo A7000-a using Tsikot Forums mobile app
- Jun 2008
- 1,741
June 21st, 2016 11:44 AM #16Yes dr. d minsan ko yan nakita sa buy & sell ng car. 😉
So it's another case of "pwede na iyan" once again. It's that kind of thinking that will put...
