Results 1 to 5 of 5
- Dec 2008
- 5
May 6th, 2011 03:17 PM #1I recently brought my 2002 Altis 1.8 because the ABS light in the panel is always on. Service said the ABS actuator gave in and also affected the ECU because there was an internal leak. I was advised that parts replacement would cost around Php113,000.! Wow, this much for an old car?
Is anybody familiar with what happened to my Altis? Any suggestion will be appreciated. Thanks!
May 6th, 2011 04:17 PM #2
May 6th, 2011 04:26 PM #3
... and maybe do a bypass so the check engine would not light up (if possible).
May 6th, 2011 05:58 PM #4
So much for Toyota parts being cheap.
But seriously... did they give you a breakdown of what's in all of that? Replacing the entire ECU costs less than that... ABS sensors shouldn't even cost a tenth of that amount.
May 6th, 2011 06:04 PM #5
Given the price, the casa is replacing the entire ABS system on the corolla, from the sensors, wiring harness, actuators and to the ABS-computer.
Nothing different from how Honda casa handled by brother's overheating CRV. Practically recommended to replace everything, radiator, hoses, fans, water pump, thermostat, etc.Last edited by ghosthunter; May 6th, 2011 at 06:07 PM.
Replaced with the Pilot Sport 5 na ata, but the available sizes aren't yet as broad as the PS4.
Finding the Best Tire for You
