Results 1 to 10 of 10
- Sep 2008
- 21
August 15th, 2009 04:44 PM #1guys patulong nmn my ride is toyota vios 1.3 E 2004
im looking for its fuel filter to check ...d ko makita
sorry not familiar with vios..
thank you po..
August 15th, 2009 06:03 PM #2
Nasa ilalim ng engine body yun bro. Makikita lang if naiangat ang car. Yan ang common design ng mga kotse ngayon. Hindi gaya ng mga luma na madaling silipin.
If you're planning to change it, mas convenient if sa gasoline station na lang. Pero if you want to go down and get dirty, jack up your car and DIY.
- Sep 2008
- 21
August 15th, 2009 10:28 PM #3sir jjmd3 thanks pero dinala ko na ito sa gas station pero d nila makita hh ...hope somebody can tell exact location of that filter
- Oct 2009
- 3
October 9th, 2009 10:58 AM #5
October 9th, 2009 11:02 AM #6
Hindi ata maganda ang design ng pakakalagay ng fuel filter para maging madali ang pagpalit o masilip kung marumi na ito at kung may laman na gasolina ito lalo na pag ayaw umaandar sasakyan. Madali ring malubog sa tubig dahil nasa ilalim .
- Oct 2009
- 3
October 9th, 2009 03:10 PM #7you can access the fuel filter by removing the seat at the back may takip siya na parang rubber, every 50k ang palit ng fuel filter, I believe same design with the altis asa loob na siya ng fuel tank.
hope this help
- Oct 2009
- 3
October 9th, 2009 03:11 PM #8you can access the fuel filter by removing the seat at the back may takip siya na parang rubber, every 50k ang palit ng fuel filter, I believe same design with the altis asa loob na siya ng fuel tank.
hope this help
- Nov 2006
- 3
October 10th, 2009 12:05 AM #9yap it's under the back seat-- sa loob ng fuel tank..
as per manual need to replace every 80K
October 26th, 2016 09:39 AM #10
pa-piggyback sa thread
for 1st gen vios, how often do we change it 40k or 80k KM?
how much is the fuel filter?
how much is the labor?
casa or outside? salamat.
high idle RPM at engine start
