Results 1 to 10 of 10
    Sep 2008
    guys patulong nmn my ride is toyota vios 1.3 E 2004
    im looking for its fuel filter to check ...d ko makita
    sorry not familiar with vios..
    thank you po..
    Nasa ilalim ng engine body yun bro. Makikita lang if naiangat ang car. Yan ang common design ng mga kotse ngayon. Hindi gaya ng mga luma na madaling silipin.
    If you're planning to change it, mas convenient if sa gasoline station na lang. Pero if you want to go down and get dirty, jack up your car and DIY.
    Sep 2008
    sir jjmd3 thanks pero dinala ko na ito sa gas station pero d nila makita hh ...hope somebody can tell exact location of that filter
    Oct 2009
    Brother Vios fuel filter is located inside the gasoline tank
    Quote Originally Posted by eiganram View Post
    thank you po..
    check mo sa manual sir, nasa engine maintenance section po yan.
    Hindi ata maganda ang design ng pakakalagay ng fuel filter para maging madali ang pagpalit o masilip kung marumi na ito at kung may laman na gasolina ito lalo na pag ayaw umaandar sasakyan. Madali ring malubog sa tubig dahil nasa ilalim .
    Oct 2009
    you can access the fuel filter by removing the seat at the back may takip siya na parang rubber, every 50k ang palit ng fuel filter, I believe same design with the altis asa loob na siya ng fuel tank.
    hope this help
    Oct 2009
    hope this help
fuel filter
