Results 11 to 17 of 17
June 12th, 2010 11:03 PM #11
lufet naman ng Fortuner na yun; it could really be a fortune to have that engine mods.
taking note that fortuner has heavier load compared to the lancer....
June 13th, 2010 03:42 AM #12
He actually did runs with the alcohol injection on vs of he gained a full 2 plus seconds with it on. That should tell you a little something about the power increase it gives a 4cly common rail turbo diesel. He runs like 4 nozzle though, pre-turbo, pre and post intercooler i believe and one just before the throttle body.
Also the time vs hp calculations dont work well for diesel due to their large amounts of TQ delivered at such a low RPM.
I know it's getting dyno tested some time this month.Last edited by dvldoc; June 13th, 2010 at 03:51 AM.
- Jun 2008
- 5
June 22nd, 2010 01:45 AM #13Hi, i am british and i did the runs with and without the alcy on to see what the difference would be, which as stated above was around 2 secs.
The autobox let me down on the change up from 2nd to 3rd as it takes so long, in fact frustratingly long..sigh.
My unichip was unplugged at the time, due to having just replaced my scv and maf sensor with a ecu reset and was checking to make sure the unit was running ok as it had been acting up due to faults on the aforementioned sensors.
Turbo is a hybrid rated to around the 250bhp mark, cant take it much above this on the stock torque convertor and valve bodies, although once i get the final tune sorted and see what the figures are, i will be removing it and getting another turbo once the torque convertor and valve bodies are upgraded, which i am looking into at the moment.
The new turbo, manifold etc is easy as i already know what i need to get to the figures i want.
On a final note, i just has to go through my registration renewal and when i went for the emmisions test the dude keep testing and testing it, reving it higher and higher.
I watched him shaking his head and go back to check his equipment twice and he kept on testing, the 0.3 figure on the test result was the worse he could get, which according to the max allowable on the diesel engine is a 3.0, so i understand now why he kept at it.
In fairness to the lancer, its a great car with a great owner, met him many times at speedlab and his problem was his cvt gbox, it just would not let him get of the line, but i am sure they will work something out for him sometime soon.
I did manage to take on a genesis v6 and a merc amg which i guess is down to a wet track and me having 4wd, but i did get spanked hard by some of the other cars running on the day, but its all good fun, which is why we were doing runs with passengers and carrying too much junk in the rear.
Hopefully by 7th aug which is the next clark drag run, i will be fully dynoed and ready for some more fun but with less junk in the rear etc, just waiting for my afr gauge to arrive so as to get the tuning done easier and get the sweet spots sorted out.
On closing, just to let you know that there will be a 2.7 gas fort being sc in the very near future and i am sure the owner will be wanting to run it hard against some other units.
Cheers
- Jun 2008
- 5
July 6th, 2010 09:53 PM #14Just a small update, was on the dyno recently to get some runs in to see what is what with my unit, not using the unichip but another one and although the test was done in top gear which made the readings out after doing the calcs, i was making 250hp without the alcy and 285hp with it on.
Will be trying to get another diagnostic run soon, with the thermocouples hooked up to monitor the temps etc so i can see it on the plot graph.
I should point out that at the time also, was only running the alcy pump at the preset 200psi, i have since turned it up to the 250psi mark now and might try going up a size on one of my nozzles.
Cheers
July 7th, 2010 02:42 PM #15
Hey, dude... I think we met a few months ago at Speedlab. (I was the owner of the red Lynx).... I remember you telling me about replacing the turbo, injectors and etcetera.
Ever think about having your converter converted to a high stall unit? Though there aren't many places that can do it... and I recall the owner of the 3 didn't have good luck with Lentech.
- Jun 2008
- 5
July 15th, 2010 05:27 PM #16Yes pare, we have met at speedlab, you are the owner of the red ford lynx.
I am making enquires already on the torque convertor and valve bodies upgrades to allow more power to be released as i am already on the limit of the stock ones.
Cheers
high idle RPM at engine start
