Results 1 to 2 of 2
- Sep 2008
- 54
February 19th, 2012 09:57 PM #1guys ask ko lang if aware kayo kung saan ako makakakuha ng helper spring para sa coilover sleeve ko.. im looking for helper spring para magkaroon ng tension or preload yun spring ko at mawala yun gap sa top spring ko to upper mount. the problem arises when heading on a rough surface or humps, nagiging loose or umaalog yun spring ko kaya makalampag, meaning walang tension yun spring because too much lowered. as far as i know, karamihan ng coilover or coil sleeve ngayon meron ng helper spring.. san po kaya ako makakabili nito? thanks.
- Sep 2008
- 54
i wonder, are the usual published suspension adjustment specifications supposed to be adjusted...
Wheel Alignment
