Results 41 to 49 of 49
June 29th, 2012 06:24 PM #41
June 29th, 2012 07:47 PM #42
June 29th, 2012 07:51 PM #43
June 29th, 2012 08:11 PM #44
Imagine going up Baguio with your left hand on the steering wheel and all along holding and sipping your Starbucks coffee on your right hand - plus chit chatting with the family while there's stop/go traffic in the U-turn near the lion's head. These times I love an automatic. Or simply driving up Tagaytay with Starbucks coffee in one hand. Talap!
I'm getting old and starting to prefer more of the relaxed driving and getting to where I am safely and no high blood.
June 29th, 2012 08:16 PM #45
Amen to that and knock on wood. Sana wag kayo kunin ni Lord.
Please drive safely and chillax.
High speed driving and relaxed driving will make you get to your destination around 13min faster.
But consider the risk to your children and spouses (kung marami kang panganay hehe ).
June 29th, 2012 10:52 PM #46
From Drive to Neutral, no problem at all. But from Drive to 3, if it is running at high speed definitely there will be some damages both in the engine and tranny
June 29th, 2012 10:52 PM #47
Its mandatory to place a child at the back seat with a car seat if possible for safety purposes
- Apr 2008
- 6,237
June 30th, 2012 01:02 AM #48Drive to neutral basically just disconnects the driveshaft. Much like a manual shifting from a certain gear to neutral, or just plain letting go of the throttle with matic tranny at higher speeds. Drive to 3 wala namang problema kung normal cruising speed lang naman. Our Revo diesel can run up to 80km/h using 3rd gear * 4000rpm. 5 speed tranny yan so even narrower spacing of gears. So its safe to assume that your engine will not blow up if you run 3rd gear at 100km/h with a 4 speed tranny. Just don't let that happen on a top speed run.
July 11th, 2012 12:48 AM #49
Lately nakapag try ako ng matic na innova d4d. And yes its more fun to drive the manual yet more relaxing to drive the matic. Both 2.5 L engines.
high idle RPM at engine start
