Results 1 to 8 of 8
- Jul 2010
- 62
September 27th, 2010 12:45 PM #1Mga Sir,
Hingi lang ako ng info kung ano gamit nyo na Spark Plug for Corolla 2E engine at kung ano yung my best performance and efficient fuel consumption.
Ang sabi kasi sa Corolla Diagram is
W16EXR-U11 spark plugs
Any comments?
- Jun 2007
- 135
September 27th, 2010 07:47 PM #2Just use Toyota Denso OEM spark plugs. Php55 each, if you like change it every 5,000kms PMS.
Kung stock mode ka, no big gains using high end spark plugs and high tension wires.
Just use the correct tire PSI, Engine timing at 10degrees and step on the gas gently. My previous car , a 1993 XE did 10kms per liter in city driving
September 27th, 2010 08:39 PM #3
I used NGK sparkplug at Premium gasoline na kadalasan kahit sinong makausap mo pag nilagyan mo ng unleaded reklamo nila may tope ang makina.
- Jul 2010
- 62
- Dec 2006
- 273
October 8th, 2010 05:53 PM #6Sa akin, NGK BPR6EY. Yung original spark plug (walang butas sa tip na kinakabitan ng high tension wires)..inaabot ito ng several years! Basta't linisin lang ang firing tip from time to time.
October 8th, 2010 06:01 PM #7
- Jul 2010
- 166
high idle RPM at engine start
