Results 1 to 4 of 4
- Jul 2010
- 166
October 5th, 2010 12:48 PM #1kasalukuyang nasa talyer po kotse ko. top overhaul, eto po mga pinalitan:
valveseal
valve guide
piston ring
timing belt
tensioner bearing
head gasket
pagnatapos po kya kotse ko bukod sa mawawala usok sa tailpipe may iba pa po kyang magbabago? gaganda po kya takbo?
October 5th, 2010 12:53 PM #2
some expected changes:
FC - its either positive or negative
Engine - its either it will run smooth or rough if overhauling was done properly or not
October 5th, 2010 01:33 PM #3
Depende rin kung tama ang pag kakaoverhaul sa makina mo . Kung maayos babalik ulit sa dati ang takbo ng makina mo at lumakas ang compression ng makina mo dahil nawala na ang singaw na nagdudulot ng loss compression. Importante rin ang correct engine timing para mas maganda idling at takbo ng makina at tipid sa gasolina.
- Jul 2010
- 166
October 11th, 2010 07:30 PM #4mga bosing, mukhang okay naman ang pagkaka top overhaul ng auto ko. tanong ko lang uli kung kelangan pa ba magbreakin? ilang kilometers? nagpalit kasi ako ng piston ring e.
high idle RPM at engine start
