Page 1 of 4 1234 LastLast
Results 1 to 20 of 67
    Jul 2016
    Hi does anyone here changed their shocks in the new Fort to have a more comfortable ride? I inquired with Atoy customs and they said better to change them with "NAM" brand or Bilstein brand. Thanks! I need you feedback on this.
    Oct 2015
    Quote Originally Posted by Eddeeward View Post
    I don't have the new Fort but I have a lot of experience with Bilsteins. All HD Bilsteins (the ones for pickups and suvs) are high pressure (relatively) gas charged and mono tube construction with digressive valving. This means small dips and bumps like rumble strips will feel harsh but deep and tall holes and bumps will be dismissed easily.
    Koni Heavy Track is much better at balancing on and off road ride quality. That's what I'm using in my pickup now.
    Jul 2016
    Quote Originally Posted by Wh1stl3r2 View Post
    Oic, Im just looking for that comfort feel during driving especially on roads with bumps. Any recommendations?
    Sep 2014
    Malabo na yan kahit paitan mo ng shocks, strut yan eh. The most primitive of all suspension systems but the most dursble
    Dapat naka wishbone and multilink self-adjusting sa rear ang suspension system
    _________________________________
    If you are wrong, turn right.
    If you are right, turn left.
    Front is double wishbone setup. Paano naging strut ang mga ladderframe suvs?
    Independent multilink sa rear also.
    Also tagtag can be lessened with proper damping rates.
    Have you tried adjusting your tire pressure?
    Bro meron bilstein comfort series diba? The hd series is for offroad ata. I was never able to double check this comfort series hirap basahin bilstein catalogue.
    Jul 2016
    What should the tire pressure be?
    32psi when cold.
    Mar 2016
    Experience ko sa 2016 Fort, Tarlac area yon. for kids, It's a fun ride parang trampoline hehe! lalo sa mga semintadong may mga hati hati.
    ok yan pag puno kayo pero kung 2 to 3 passengers? parang jeepney ang ride akala mo leaf spring 28psi front tapos sa rear 30psi.
    magiimprove ang ride nyan pag lagyan nalang ng mga barbell.
    pero kung ride comfort hanap mo dapat sana Innova nalang pinili mo.
    Jul 2016
    Though not fort, ung 08 everest namin pinalitan ko ng rancho 5000 series front and rear. Ang laki rin ng improvement sa ride mas naging comfortable.
    pero pansin ko medyo naging boaty pag high speed na takbo mo sa lambot ng bound at hard ung rebound.
    I wouldnt recommend lowering tire pressures to compensate for a smooth ride especially if below sa recommended ng manufacturer(sticker sa driver door) Nag wear ung outer sides ng tires ko faster compared sa center portion due to underinflation running 28 cold.
    Jul 2016
    Quote Originally Posted by Vensong Quezon View Post
    Hahaha okay thanks!
    The Bilsteins will be noticeable in large ruts and also at speed on the open road. As for the small imperfections, it depends. But either way, the shock upgrade is good. Try also considering Old Man Emu.
    I understand that tagtag is subjective....
    What I do not understand is why do you have to change the shocks of a brand new vehicle?
    [Unless you're telling me that it is as bad as the old Fortuner. Is it?]
    _/_/_/
    30.5K _/_/_/_/_/_/_/_/_/_/
    Mar 2016
    Quote Originally Posted by Janemar View Post
    Yong 28 kasi pag mainit ang panahon pasado narin yong ride comfort, but still matigas parin ramdam na ramdam mo kalsada. papalo ng around 32 when running na. kung 32 agad when cold napaka harsh na ng ride lalo kung ilan lang kayo. iwan ko pero pag puno ok na yong ride. kung city siguro ok lang ang 28 since mabagal lang naman ang takbo.
    The new Fort is incredibly bouncy if you are driving alone, though not jolting/tagtag like the old one. I much prefer the ride of the old monty... Is there anyway to tighten the road feedback?
    When you say bouncy,- more like a leafspring suspension, bro?
    Parang nangangabayo???
    _/_/_/
    Yep, most evident along light bumps as what Vensong Quezon described. Parang nasa trampoline.
    _/_/_/
    In which case,- it might have been inspired by the Nissan Vanette bro...
    To me, that is something that will be disturbing, indeed....
    _/_/_/
    _/_/_/
    The new Toyota avanza is as jittery and bouncy.
    The folks at topgear, when they made the comparo didnt even mention this issue.
Toyota Fortuner 2016 changing front and rear shocks.
