Results 31 to 40 of 67
- Mar 2016
- 164
September 6th, 2016 11:34 AM #31
September 6th, 2016 01:37 PM #32
September 6th, 2016 02:51 PM #33
I see I was mentioned here...
Like Monseratto says, the Fort is much better than the old one, but still too stiff for family duty. I figure the correct approach to this issue will be more progressive shocks plus a change of footwear... perhaps to tires with softer sidewalls.
Lowering pressure on the stock tires will not help much... if the sidewalls are stiff, all this will do is make the ride bouncier and wear out your tires' shoulders more. Having a more comfortable "premium" tire will give you a smoother ride even at the same 32 psi.
I don't think there's a need to change anything at the front. It's the rear set-up that has always been the problem for the Fort.
Be interested to hear what the final solution is.
- Oct 2015
- 1,054
September 6th, 2016 04:05 PM #34That's exactly it.
*niky
I figure we needed Batman hence the bat signal hehe. Are there any progressive shocks? King lists progressive springs but they are all raised by around 20mm.
*Monseratto
If you'd like to be a guinea pig for the progressive raised springs I could order them.
- Jul 2016
- 72
September 7th, 2016 10:12 PM #35
- Jan 2017
- 3
January 18th, 2017 08:23 AM #36Hi sir. I have a fortuner 2006 and i changed the front spring with a fortuner 2013 to 2015, the wire diameter is much smaller compare to the stock. Then i also replaced the rear spring with an innova spring since the only difference is that is has smaller diameter of wire. Just add a 2" quicklift sr performance at the rear. I assure you will have a comfotable ride
Sent from my E5663 using Tsikot Forums mobile app
- Jul 2016
- 72
January 24th, 2017 06:46 AM #37
- Jul 2016
- 72
January 24th, 2017 06:49 AM #38
- Jul 2016
- 72
January 24th, 2017 06:52 AM #39
- Sep 2015
- 51
February 13th, 2017 03:01 PM #40OEM shock absorber are the most comportable. Shock replacement for sport/off road purposes are needed but not for daily driven. Making it too soft will compromise the safety ot the vehicle and I dont think you can get aftermarket shock softer than OEM. Most replacement always the same as original or harder. If you try to re-engineering it for your purpose you will fail.
Sent from my GT-P7310 using Tsikot Forums mobile app
Suzuki JIMNY [merged threads]
