Results 21 to 40 of 67
    When you say bouncy,- more like a leafspring suspension, bro?
    Parang nangangabayo???
    _/_/_/
    30.5K _/_/_/_/_/_/_/_/_/_/
    yes ganito rin experience ko sa new fortuner. 6 kami lahat and sa 3rd row pa ako nakaupo. bouncy talaga lalo na sa cemented highway. mahirap din ang egress and ingress sa 3rd row. pang kids lang talaga sa 3rd row. sayang type ko pa naman exterior look but can't tolerate the ride.
    Sent from my SM-A9100 using Tapatalk
    Aug 2004
    I see I was mentioned here...
    Like Monseratto says, the Fort is much better than the old one, but still too stiff for family duty. I figure the correct approach to this issue will be more progressive shocks plus a change of footwear... perhaps to tires with softer sidewalls.
    Lowering pressure on the stock tires will not help much... if the sidewalls are stiff, all this will do is make the ride bouncier and wear out your tires' shoulders more. Having a more comfortable "premium" tire will give you a smoother ride even at the same 32 psi.
    I don't think there's a need to change anything at the front. It's the rear set-up that has always been the problem for the Fort.
    Be interested to hear what the final solution is.
    Jul 2016
    Wow, so many options.....now I don't know what to do[emoji1]
    Import Elementz Car Accessories
    2016 to 2017 Toyota Fortuner TRD Suspension set.
    Same as sold in Toyota Philippines Casa.
    80,000 / 4 pcs Set
    80,000 / 4 pcs Set
    Nice bro. Have you fitted it yet? Any feedback on ride quality?
    Sep 2014
    Kaya matagtag ang mga bago PPvS. Is becusse they're sporting 265/60R18 instead of the usual 265/65R17.
    I've noticed this when riding the Wildtrak (265/60R18) and the Pajero (265/65R17) Matagtag na Pajero Pero grabe ang Wildtrak pag tumama sa Truck lane ng C5.
    So, I guess tiis kayo kayo mga naka 18" rims with PPv body.
    I've notcced that the trailbazer and MuX seem to ride well on visual, maybe because they're using 16 rims with larger tires,
    _________________________________
    If you are wrong, turn right.
    If you are right, turn left.
    Aug 2014
    2016 Fortuner 2.4G yong sa Tita ko kaya 265/65R17 at Zumba edition ang tranny. matigas sya at bouncy gaya ng mga pagka-describe nila sa previous page dito, kaya baka nga talaga suspension upgrade ang best option.
    Mar 2016
    Quote Originally Posted by bulawbusiness View Post
    Hehe! suspension upgrade for comfort? good luck!
    Quote Originally Posted by Eddeeward View Post
    Hi does anyone here changed their shocks in the new Fort to have a more comfortable ride? I inquired with Atoy customs and they said better to change them with "NAM" brand or Bilstein brand. Thanks! I need you feedback on this.
    23k-26k ang nam shock absorbers while retaining your coil springs.
    Jan 2017
    Hi sir. I have a fortuner 2006 and i changed the front spring with a fortuner 2013 to 2015, the wire diameter is much smaller compare to the stock. Then i also replaced the rear spring with an innova spring since the only difference is that is has smaller diameter of wire. Just add a 2" quicklift sr performance at the rear. I assure you will have a comfotable ride
    Sent from my E5663 using Tsikot Forums mobile app
    OEM shock absorber are the most comportable. Shock replacement for sport/off road purposes are needed but not for daily driven. Making it too soft will compromise the safety ot the vehicle and I dont think you can get aftermarket shock softer than OEM. Most replacement always the same as original or harder. If you try to re-engineering it for your purpose you will fail.
    Sent from my GT-P7310 using Tsikot Forums mobile app
    Quote Originally Posted by redled View Post
    Dobinsons and toughdog suspensions are popular for a reason.
    Even fox suspension is standard for the ford raptor.
    Consumers cant re-engineer suspensions but they can purchase consumer products that were tested by specialists.
    Original post is for his Fortuner's riding comfort, and only shock absorber he want to replace.
    Oct 2015
    *Eddeeward
    I think 20k and up for a set of 4 springs. But Stock is right. It is better to get model specific shocks and springs as a set that has been tested by specialists. Fox coilovers are awesome. Have ridden on the Navara application and all I can say is wow. The only negative I could not live with with that type of coilover is the use of spherical bearings. Too noisy for me. ☺
    Jul 2016
    Quote Originally Posted by Wh1stl3r2 View Post
    *Eddeeward
    Thanks!!!
    Jul 2016
    Has anyone tried the trd suspension?
    ah nakita mo na yun 30k na shocks and springs? without labor pa yun diba?
    Apr 2009
    what about the Rancho RS9000XL? Will its 9-setting adjustable set up help lessen the bounciness of the rear?
    Contemplating to install these Ranchos in the rear muna..
    I see many previous gen Forts sporting Ranchos on their rears & their feedback was, the ride improved a lot. Also, maybe you guys can share the Rancho RS9000XL part # for the rear of the 2016-17 Fort?
    Tnx!
    Oct 2007
    How about OME BP51 bypass shock absorber? May nakapag try na ba or any comment?
    Sent from my Nexus 7 using Tsikot Forums mobile app
    Apr 2014
    What about ridemax x lovells? They say its pure comfort daw based on fb posts, can someone confirm this?
Toyota Fortuner 2016 changing front and rear shocks.
