Results 631 to 640 of 926
- Feb 2014
- 2,694
September 26th, 2018 06:50 PM #631
- Mar 2018
- 13
September 26th, 2018 07:55 PM #632I think it is called Unibody frame not Monocoque.
just my 2 cents.
- Sep 2007
- 267
September 26th, 2018 08:36 PM #633Wrong again. Those "rails" that you point out are not contiguous with the ones you see in front. The rails you see in front either slant towards the side sills or terminate at a cross member below the passenger cabin. The rear ones you see are separate pieces that are attached to the back of the passenger cage. They are not single continuous rails that run from the front to the rear (aka longitudinal rails). The Avanza/Rush has those two signature longitudinal rails. The pieces you highlighted are not rails, they are structural members of that particular model's monocoque design.
Please, we can have a discussion without you being condescending.
PS: Bro, parang may tagas near sa fuel tank area mo ah. The bottom of the flooring looks wet.
- Feb 2014
- 2,694
September 26th, 2018 10:03 PM #634sorry
i'm just annoyed by this "body on frame" claim so let's put it to rest for good
so here's the avanza "chassis". as you can see it's made of SEPARATE PIECES that are spot-welded together. this "chassis" cannot stand alone so it still relies on the rest of the body to achieve rigidity. that's why these pieces are spot welded onto the rest of the body.
this is exactly what a monocoque is
if you look under a typical sedan you'll see pretty much the same thing, with minor variations
under no circumstances can this be called "body on frame". it simply isn't
PS don't worry bro wala naman leak. wala lang undercoating yung darker sections...
- Jan 2008
- 4,726
September 26th, 2018 10:34 PM #635Para sa akin simple lang.. kung pwede i-angat yung body sa chassis.. body-on-frame yun.. kung naka incorporate yung chassis sa body. Monocoque yun. MONO means ONE..
Yung rush para sa identification ko ay monocoque design kasi di mo pwede i-lift yung body from the chassis like sa pick-up or suv or auv
- Feb 2014
- 2,694
- May 2006
- 32
September 27th, 2018 12:02 AM #6375 Car Chassis Types
(5 Car Chassis Types | DoItYourself.com)
Whether you are building a car from scratch or are simply interested in the bodywork of a car, recognizing different types of car chassis can prove beneficial. This can also be of assistance in helping you to choose the correct type for the car.
1 – Ladder
A ladder frame car chassis is a common type of frame used as a base for vehicles, creating a solid base from the shape that the name suggests.
2 – Backbone
A substantial central component is necessary for a backbone car chassis, connecting the front and rear of the entire frame.
3 – Monocoque
A monocoque car chassis is one that uses metal that is molded from sheets of the material, which is the same method used to build other parts of the frame. This type of chassis is similar to a unibody type.
4 – Space
A space chassis can also be known as tubular even though it is not tubular in the true sense. The components are welded together to create a strong frame that comprises some flexibility.
5 – Combination
You will often find that a car chassis is not any single types, taking elements from a range of different types to create a version that is best suited to the car frame.
- Sep 2007
- 267
September 27th, 2018 02:02 AM #638Never insisted it was body on frame. What I said is that it's a monocoque implementation of a ladder frame design. So I agree with you that it is a monocoque body - just that it is of a ladder frame design. The confusion arises from the conventional understanding that ladder frame = body on frame. Which in this case is not.
Our little discussion here is probably the exact reason why so many are also confused. Search the following complete with quotation marks: "built-in ladder frame" monocoque body
It is apparently a thing...
- Apr 2018
- 84
September 28th, 2018 04:06 PM #639I just really wished they used a slightly bigger engine really as that would have done wonders for the Rush and their pockets too haha
Come on toyota you could have done better than that haha
You could have obliterated all the competition in this segment if you used a bigger engine. Tsk tsk tsk, all that "Rush", only to come up short.
September 28th, 2018 04:19 PM #640
It is repairable. But as oj88 mentioned, it is messy (when repaired) and best used as a last resort.
Liquid tire sealant
