Results 8,891 to 8,900 of 8993
- Mar 2018
- 263
October 24th, 2018 07:31 PM #8891I purchased a 3rd gen RAV4. Key is with immobilizer din and spare key lang and also without remote. Meron naman nakapag cioy from spare and the copy meron na remote. 7500 charge sakin at that time around 2016. Afterwards pwede naman pala i diy. You can buy the key with immobilizer sa ebay, kasama na pati software. Or you can check with keynamics PH. Safe yan kung may immobilizer kasi they can erase the lost keys sa system. Pag wala immobilizer, mas risky, kasi the lost key can start the car.
Sent from my ONEPLUS A3003 using Tapatalk
- Nov 2018
- 7
November 29th, 2018 07:31 PM #8892
- Jul 2013
- 154
December 13th, 2018 08:13 AM #8893posible na magkakaproblema sa engine mount ko after 5 years? 25k odo ko hatid sundo lang sa skwela.
Vibration when stationary - Maintenance & Repairs - MyCarForum.com
parang similar sa kanila ung prob ko. pero slight vibration/shake lang. napansin ko ngaun pag ON ang aircon napapansin ko sa everytime nagbbreak to slowdown or stop sa traffic tapos galaw ulit pero brake lang nilalaro ko. pag off ang aircon parang wala akong nararamdaman. once last week ata nung nakapark ako pababa sa steep road nag vibrate/shake ung dashboard medyo may sound talaga. ON ang aircon din pag off parang wala din ata. kakaservice ko lang sa toyota for 25k pms nung oct. once a year ako nagppms. TY!
- 52,731
December 13th, 2018 08:55 AM #8894puede po.
1. wear-and-tear by an aggressive user;
2. factory defect.
3. both of the above.
alas, engine supports are considered wear and tear items. one might have a difficult time convincing the casa that the low-mileage support broke because it had a manufacturing defect.Last edited by dr. d; December 13th, 2018 at 09:00 AM.
- Jul 2013
- 154
December 13th, 2018 11:08 AM #8895doc ty! dahan2x lang ang takbo ko doc city driving lang dito samin. galing pala ako sa shell pinacheck ko lang muna ung engine mount, sparkplugs, air filter bago ko dalhin sa casa kasi per hour diagnosis dun ni una nung sinabihan ko ung mechanic na ganun parang may slight vibration more noticeable pag on ang aircon and medyo kulang sa hatak ung takbo ko parang ang bigat sabi nya ipacheck ko ung compressor. pero pinacheck ko pa din talaga ang sparkplugs. pag open basa ng oil ung isa umakyat ung oil. sabi nya valve seal daw. nilinis nya obserbahan ko kung parang mabigat na naman takbo ko ipasok ko na sa casa para mapalitan. doc sa tingin niyo po posible na dun na galing ang slight vibration/shake? wala na ba sa engine mount/support o compressor? hindi naman parati navvibrate pero meron talaga. ngaun para naging ok ung hatak ulit light apak lang sa gas. ty!
- 52,731
- 52,731
December 14th, 2018 12:07 AM #8897if the plug is oil-wet, i would probably think of plug mis-fire and/or poor compression, as the probable cause of the vibration.
i'd probably see what can be done to get rid of the oil getting to the sparking plug.
- Jul 2013
- 154
- Jul 2013
- 154
December 15th, 2018 03:05 PM #8899doc everyone patulong ulit hindi ako mapakali kasi. after ko nagpacheck sa shell pumunta ako sa autoshop dito samin para patingin na kung bat nababasa ung isang sparkplug. hindi ako makaantay kasi ayaw na tumanggap ni casa 2 days na kasi daming nagpapagawa. nung binuksan sabi palitan ng gasket pero wala silang gasket sa labas pa bibili. nung chineck na ung gasket maayos pa naman daw kasi hindi naman matigas. nilagyan na lang mighty gasket ata un ung parang sealant hindi ako sigurado. nung binalik akyat baba ang idling and may continouos clicking sound sa engine ata. nung pinalitan ung sparkplugs lahat naging ok na bosch ung pinalit 230 isa. hindi naman daw sira ung sparkplug ko sabi nung mechanic nung una. ngaun nagaalala ako dun sa mighty gasket na nilagay. ok lang ba ung ganun? hindi po ba magkakaproblema un pagtagal? gusto ko kasing dalhin na lang sa casa palitan ng gasket talaga. gusto ko din palitan ng oem denso plugs sa casa. and ung cabin filter na nabili ko sa casa pwede bang linisin lang un? tiningin ko kanina dumi tapos sabi ni casa P2100. last year kakapalit ko lang nung 20k pms. ty ty talaga!!
- 52,731
December 15th, 2018 07:31 PM #8900this is my opinion only.
if the problem has dis-appeared, just enjoy driving your car. worry about it when the problem returns.
bosch is a good brand.
just because it was a non-casa fix, does not mean it is a substandard fix.
fixing a gasket by putting in filler? i do not know. as in, hindi ko alam kung ok ito o hindi.
i gently hand-wash my cabin filter. i manually pick away the layer of dust from the filter element's surface. while some folks say it can not be done and should not be done, i do it nevertheless. kuripot ako, e.
after about three washes, my filter would have become distorted. that is when i discard it.
i recently bought a cabin air filter for vios, for 450 bucks, in the friendly auto parts store. casa prices are expectedly bloated.
high idle RPM at engine start
