Results 8,231 to 8,240 of 8993
- 52,731
September 26th, 2015 10:57 AM #8231- - - - - - - - - - - - - - - - - - - - - -
i used to have an older, non-toyota car. the manual says i can use as low as 91 octane. which i did. but from time to time, going up a steep ramp, the engine does knock a bit.. so i just turn the aircon off, and the knock disappears.
i suppose, knowing what your car can and can not do, and what you want it to do, helps in determining what fuel the user will choose to use.Last edited by dr. d; September 26th, 2015 at 11:03 AM.
September 26th, 2015 11:54 AM #8232
less drag and noise isa na rin sa karagdagang aspeto no worries about ventilation kasi may air intake at outtake naman and for now mas pansin ko mas malinis ang engine bay ko at wala na rin un mga balahibo ng pusa, i got peace of mind kht na sumayad ako sa nga humps kc well protected yung ilalim ng engine ko lalo nanun oil pan ko
September 26th, 2015 12:05 PM #8233
Guys normal pa ba yung pagtunog ng break creaking sa left side ng driver seat (front left wheel) kapag napreno ka in situation like idle to go then stop or slow moving traffic then break mag 4 months na yung 1.3E AT ko. Nung una di ko pinapansin sabi kasi ng Tito ko normal daw yun kasi bago pa ang break. Odo reading is 3800+ km
- 52,731
September 26th, 2015 12:33 PM #8234- - - - - - - - - - - - - - - - - - - - - -
check, sir.. is the sound coming from the left front wheel, or is it coming from under the driver's flooring?
my innovas are like those. it's not coming from the wheel, but from under, somewhere.. and i have long ago given up on it. it does not affect drive-ability..
also, is it possible, the sound is coming from the driver's seat itself? perhaps a mounting bolt is loose.. just tighten it, sir. madali lang yan. and if you are lucky, the dealer/manufacturer will have included a wrench inside the tool pouch, that fits the bolt.
- Sep 2011
- 262
September 27th, 2015 09:45 AM #8235Question, bakit ni re recommend ng service advisor ang engine flushing pag nag pa pa change oil tayo? Tapos pag kinuwestyon mo ay sasabihing kailangan daw talaga yun...
- 52,731
September 27th, 2015 09:51 AM #8236- - - - - - - - - - - - - - - - - - - - - -
no, engine flush is not necessary. i always decline, and my warranties are still intact.
if it were necessary and i declined, the warranty will have been void then and there.
just decline nicely, "bossing, huwag na lang.. medyo bilang ang budget namin today..".
so why recommend it? increased income... on their part! and, well... some people believe in it.. some... don't.
quripot talaga si dr. d...Last edited by dr. d; September 27th, 2015 at 10:02 AM.
- Sep 2011
- 262
September 27th, 2015 04:08 PM #8237May nabasa kasi ako, sir na it will do more harm than good sa makina natin esp. kung wala naman syang ipa flush
- 52,731
September 27th, 2015 10:52 PM #8238
September 28th, 2015 03:34 AM #8239
Flushing is not necessary. Actually, noong araw hinde rekomendado ng mga casa yan mga flushing & additives.
Ang importante is regular ang maintenance mo and you are using the recommended oil viscosity grade & API rating para sa sasakyan mo.
Ang langis ay kompleto na sa mga detergents at additives para bigyan ng sapat na proteksyon ang engine.
Mag dedepende na lang sa driving habits mo at tamang pag maintain ng sasakyan.
Yan engine flush na yan may mga kemikal yan. Basically petroleum based then at ang malaking porsiyento nito ay kerosene.
Pag hinalo yan sa engine oil at pinaandar ang engine, lahat ng pinupuntahan ng engine oil ay pupuntahan din nyan. Then pag nag drain eh yun nasa oil pan or oil sump lang ang lalabas, may mga langis langis na maiiwan sa ibang siksik na area na contaminated na ng engine flush.
Then pag nilagay mo na yun new engine oil then makokontaminate na rin sya.
HTH
HTH
- 52,731
September 28th, 2015 08:43 AM #8240engine flush is just like binabanlawan ang labada.
tinatanggal ang bakas ng luma at maruming oil, para pagbuhos ng bagong langis ay wala nang lumang langis na madumi.
some believe in it, others do not.
Xiaomi E-Car
