my guess the idling rpm would depend on:
1. what engine oil is used.
2. outside temperature.
3. a/c is on or off.
4. what type of fuel/brand is used.
these are just guesses and I'm no expert.
question po sa mga guru...
what is should be the rpm para mga ECO LIGHT sya?
kasi i did a light press sa gas, pero hindi pa rin umaandar eh. ilang subok ako, pero ayaw pa rin umilaw eh. one time lang naka tsamba, when i was during on a traffic in edsa... after i had to break for a minute, nawala na sya eh
what is the advantage of the ECO ON and OFF? malaki ba ang save sa gasoline? performance?
maraming salamat![]()
Dami mo freebies sir, in house ka?
Feeling ko maganda freebies pag end of the month ka kumuha. Yung sken dec ko nakuha (end of the year, hahabol sa quota) nakuha ko 35k discount, ussual freebies plus side visor, bosch europa horn, luggage tray, binigyan pko mga panlinis at wax, kanebo, air spencer. Yung tint and seat cover dko na kinuha. Cash payment nga lng.
gara ang tagal talaga ng plaka ngaun last august pa ko 2013 mag 6 months na ko.. buti papasok sa office sa makati di ako pinapara ng mga gutom na TE..
Hi guys,
my family car po kami vios e M/T... nilabas nung Jan 9... maask ko lang po ilan po ba tire pressure dapat natin? TIA..
More power po sa mga vios users
Theres note is indicated on the driver side. Pag bukas mo ng pinto sa may gilid usually sa ilalim siya ng lock hook ng pinto. Also, reading the manual is a big help.
Cheers!
Sent from whatever device I got my hands on via Tapatalk
thank you for the reply... 220 210 nakasulat iba yta units pag sa gasolinahan magpapahangin e...
Yep. Those are in kPa (kiloPascals) units. Meron switch yung air compressor machine ng mga gasolinahan (unless analog type siya). HTH
32 and 30 psi yan paps.
Try mo 33 psi all tires. Ako naka35psi all tires.
Sent from my GT-I9505 using Tsikot Forums mobile app
Thanks for the reply Sir, however isn't it that plate numbers starting with F is assigned to Region VI (Western Visayas Region)? The first letter tells about the geographical designation. Does that mean that LTO has already revised the designations?
Sent from my Nexus 7 using Tsikot Forums mobile app
That really should be the case na sa region 6 naka assign ang letter F. ang nangyari parang kinuha ng lto ncr ang mga plates ng region 6 dahil naubusan na sila ng plaka, ang region 6 medyo madami pa sigurong stocks ng plates.
Sent from my ALCATEL ONE TOUCH 5020E using Tapatalk
