Page 1 of 2 12 LastLast
Results 1 to 20 of 37
    Apr 2012
    Mga Sirs,
    I just bought a new Innova J Diesel last week. It's still is not with me, though, because the Silver color that I ordered is still unavailable. I would like to ask your expertise regarding the proper way to break-in my unit. I am pretty sure that there will be different opinions and practices so may I request for the model year of your unit, way of break-in, and the status of your unit after the break-in. Also, some technical analysis for your preference will be of great help.
    More power to all.
    Aside from the break-in procedure, better also to ensure that you practice the proper turbo cool down before turning off your engine to lengthen the lifespan of your turbocharger.
    Apr 2012
    Thank you sir. Will keep that in mind.
    Pitik pitik to 100-120kph.
    Basta no jackrabbit starts. ;)
    Jan 2012
    Will it also apply on the Vvti variant? wala pa din ma kuhang silver ang SA namin.
    Quote Originally Posted by markduguran View Post
    Yes sir, most cars applicable siya.
    Based from experience, mas nakaka-ganda yan ng FC. You'll notice it after the 1k check-up. Wag lang talaga papaabutin sa 4000rpm.
    And as you can see naman, coming from the Sta. Rosa plant hataw rin talaga yung mga units na yan sa expressway.
    Sep 2011
    break-in 100-120 sprint sprint lang
    ako. hard break in ginawa ko..
    nung pag kuha sa casa na sagad ko si innova..
    ang alam ko nga rin na ibreak in na raw at hataw na sa sta rosa daw bago i deliver sa toyota :-)
    Apr 2012
    Sir,
    Pano po ba ung jack-rabbit starts? Ngaun lang kasi ako bibili ng brand new na sasakyan e. Thanks
    Quote Originally Posted by mib904 View Post
    Sir,
    Parang taxi. From stop, hataw agad.
    Basta huwag mo bibiglain ng hahatawin agad from stop. Pwede na yung while cruising ka at 5th gear, 80kph sa NLEX. Saka mo pitik pitikin ng 100-110-120kph. Basta huwag ka rin bababad sa speeds na yun. Pitik lang.
    Feb 2007
    Ano ang impact sir pag binabad ng matagal? nabasa ko rin sa manual yun pero di ko magets kugn bakit bawal.
    Kailangan pa ba "break in" ngayon?
    ang alam ko hindi na kelangan i break in ang mga bagong sasakyan ngayon eh, nung bumili kami ng 1.3e na vios tinanong ko kung ibbreak in pa, sabi nila di na daw applicable sa mga bagong labas na sasakyan ngayon, pati nung bumili din kami recently lang ng 2012 hyundai accent, hindi na din daw kelangan, siguro depende nalang sa driver kung gusto ipractice ang pag break in kasi yun ang kinasanayan natin. pero hindi na daw talaga kelangan yun.
    Quote Originally Posted by j_dipad View Post
    Tingin ko nga hinde na rin kailangan.
    Sa expressway palang hataw hatawin na ng mga taga-deliver sa CASA yung unit mo. Dati nga, may sumasabay sakin sa 130kph na mga fleet ng mga bagong Vios.
    nakasanayan na kasi... kahit nga yung tamiya dati e bini-break-in din pag bagong bili... as in pinapatakbo ng nakatihaya hanggang sa ma-drain yung bagong set ng batteries... ganon daw ang pag-break-in
    Aug 2010
    basta pagka-kuha mo, Drive it real hard like racers do'....vary your speeds 80 - 100- 120 kph, don't stay on constant speed but AFAIK di na kailangan i-break in break pa yan mga ganyan, basta hataw-hatawin mo, yung bagong pick-up nga nabili ng relative ko, pagkakuha namin sa casa, hinataw-hataw na namin agad, 3 days after we got the unit, tinakbo namin pa-Rizal to Quezon, zig-zag, ahon dito, lusong doon,... di naman yan tulad noon mga sasakyan noong 90's na kailangan wag ka muna mag-eexceed ng 80kph kapag wala ka pa sa 100kms odo reading.
    Basta ako kapag nakakuha uli ako ng brand new, walang break in break in sakin...
    Hatawin ko agad. Para hangga't maaga, makita ko kung may problema or wala. Kung meron, warranty claim agad!
    Oct 2011
    hindi na, live in na ang uso ngayon.
    BTT:
    just make sure that you have a radar detector pag humataw sa expressway.
    Feb 2007
    Quote Originally Posted by zap.FREEDOM View Post
    sir, bakit anong meron ngayon na wala noon na hindi na kelangan ibreak in?
    Oct 2011
    mas bago at moderno na ang teknolohiya ng ating makina ngayon kumpara noon.
    May 2010
    You don't need to break in your engine like in the olden days.
    Why? new engines of today has now a "Ceramic Coated or Chrome Coated Cylinder Barrel/Sleeve."
    In layman's term, the cylinder walls where the piston is has a chrome coating that makes a slippery surface that will make your engine more durable, efficient and plus there will be lesser friction thus lower engine heat.
    Contradictory to old engines, those have Steel Barrels or Steel Cylinder sleeve that needs to be broken in so the piston rings can fit properly while it kinda shave the barrel to make the piston and the rings slide in its size.
    what you really need to do based on the manual is to take care of the vehicle for the first 1000km and observe the changes after.
Break-in
