Originally Posted by
vinj
AFAIK the D4d issues isnt really that much of an issue on the 3.0.
However given it is a 6-7 year old vehicle already, do expect the following which are pretty much the same issues on any vehicle as it ages under normal wear and tear:
- you may have to service the injectors sometime while it's under your ownership
- leaks in the engine
- turbocharger leak. 100K+ ito sa CASA since they'll have you change the whole assembly and when i consulted some turbo rebuilders, mas complicated pala yung mga bagong turbo pag nagkaroon ng tagas so rebuilds are not yet fool proof (although i saw someone selling at Sulit for half the price).
- you'll have to check your A/T to make sure it's working well
- check the 4x4 drivetrain to ensure its running well
- Full service over of the unit (change all fluids, belts, water pump, filters, clean sensors, intake plenum, etc.)
If you want to mod it a little, try the Ironman suspension kits as well. Cheaper than OME and they perform well. Samahan mo lang ng magandang A/T na tires.
