pahelp naman po..
newbie palang po ako... and im having a problem with my ae92.. and goes like this....
cold start> hard starting as in HARD and very shakie... dark black smoke is very visible nakakahiya nga s kapit bahay.. and mabaho sya.. but once na naitakbo ko na sya nawawala nmn..
idle> unstable idle sya.. mapalag.. up and down ang idle nya pero good thing hindi naman sya namamatay.. and kapag mainit naman na sya.. one click starting na sya.. but the idle still the same
what ive already done is this...
ive check all the vaccum lines baka my vaccum leak.. wala naman all vaccum lines are in good and thight condition.. napansin ko lang naka disable na yung line fron tvsv to aap (is it good or bad?). and yung tvsv nya nakita ko na putol so tinanggal ko.. wala nang laman sa loob (wala na yun rod and piston valve nya na nagccontrol sa air flow ng vaccum) ok lang po ba yun? ibinalik ko yun tvsv by bonding it with epoxy and im pretty sure na wala air leak s tvsv.. pina check ko na s mekaniko na malapit dito samin.. ang sabi naman mukang kailangan daw buksan ang carb ko..
kaya nagbasa basa muna ko s mga forums regarding my problem.. im having this problem since july 1, 2013
any suggestion or help, ako po ay nagpapasalamat na ngayon palang..
