Page 1 of 2 12 LastLast
Results 1 to 20 of 34
    Apr 2013
    Ask lang po if you had experience already good idling yung vios but poor acceleration when running no matter how you push the throttle pedal? We already replaced a new fuel pump pero ganoon pa din po ang problema. Unless apakan ng todo (deep press) yung gas pedal dun pa palang mag-accelerate. Pinacheck na rin po namin yung ECU pero normal naman po ang result. MAF sensor, Oxygen sensor and throttle position sensor pinacheck na din po kaso same problem pa din. Any idea po para masolve yung problem? salamat po
    Feb 2009
    Quote Originally Posted by rush View Post
    check the basic items first. check the air filter, check the fuel filter, check the engine oil quality and level, check the fuel quality, check the ignition. if you can, take pictures of the spark plug terminals with labels which cylinders they were pulled out of and attach it to your response post
    Sep 2006
    Bro ano model ng vios mo? Nagpalit ka ba yun fuel filter tsaka yun strainer sa fuel pump?
    Apr 2013
    I already checked and clean air filter and even replaced fuel filter and change spark plug too. But I haven,t changed engine oil and tune up yet. I'll try to do perform these. thank you po
    Apr 2013
    Vios 1.3E 2008 bro. Kang bibili ko lang 2nd hand. Unang scenario tinanggal yung battery then kinabit ulit. PagkaStart ng engine ang lakas ng vibration ng engine. Ang sabi dahil daw sa pagkakareset ganun daw talaga ang mga vios kahit na new models.(wala naman ako naencounter na ganun sa ibang sasakyan, thinking na siguro nga ganun lang talaga. 500rpm). So tinest drive namin ok naman yung performance. After ng test drive kinuha ko na. (ang mali ko hnd ko tinest ng long drive). Noong pauwi na, nagloloko na namamatay na yung engine at very low yung rpm. palyado yung makina at very low speed and 700-2000rpm. Parang ang gusto ng engine more than 2krpm at more than 60kph. Once na bumaba sa rpm and speed palyado na ang makina. Nilinisan ang air filter at nagpalit ng spark plug medyo gumanda ang takbo hindi na sya palyado at first pero kapag me nakalayo layo na ng konti bumabalik yung sira.
    One day pinalitan ng fuel pump buong kit gumanda naman yung takbo hindi palyado in continues drive pero kapag inapakan mo yung gas pedal kahit full na apak hindi umaangat yung rpm. Hindi proportion yung apak ng gas pedal dun sa rpm reading (very poor acceleration hindi ka pwede umovertake parang kulang lagi ang supply ng gas sa engine) unless deep press.
    Bago naman binili tinanong namin if binaha ba yung car sabi hindi. Bro pano ba malalaman if binaha yung unit? thanks
    Balik mo na lang yan. Sana di mo na pinapalitan ng kung anu-ano pa. Manloloko yan. Post mo dito name niyan sa goonsquad.
    Apr 2013
    Binabalik ko po yung unit noong araw din na nabili ko kaso ayaw nya kasi nagkapirmahan na daw. Hindi ko pa naiuuwi yung unit that day pero ayaw talaga. Pero kapag hindi maayos try ulit pakiusapan baka gustuhin na nya. Noong pinalitan naman po yung fuel pump alam naman po nya at nandun din sya noong pinapalitan.
    Siya ba nagbayad nung fuel pump? Malamang binenta niya yan kasi di niya rin mapaayos ayos. Nakakainit ng ulo yan.
    Apr 2013
    Quote Originally Posted by beni23 View Post
    Oo sya din nagprovide ng fuel pump.
    sad to say naisahan ka.
    pero since wala namang choice, pa scan mo na lang para matumbok yung eksaktong sira.
    mahirap kasi manghula eh, mas gumagastos.
    Apr 2013
    Quote Originally Posted by 1D4LV View Post
    Pinascan ko na din po sa casa and normal result naman po ECU. I-try ko po muna change oil and tune up. salamat po.
    Nov 2007
    bro medyo nagmdali ka ata sa pag buy nun vios ? Sana bago mo tinigilan i test drive at binayaran super sure ka muna sa unit ...
    Madali naman itama yan hindi naman kumplikado ang vios hanap ka nalang ng maayos na mekaniko para dyan good luck syo pero tama si 1D4LV naisahan ka nga halos
    Apr 2013
    Quote Originally Posted by kenzie View Post
    Thanks bro sana maayos pa. Pero kapag hindi maayos post ko dito yung dealer baka may maisahan pa sa mga member/s dito tsikot e.
    Apr 2004
    So sorry TS..I suggest you seek legal remedies against this dealer..you deserved fair justice..kakarmahin din yang mga lowlife na yan..
    Was it a car dealer?
    Err. Suntok nalang talaga sa buwan makahanap ng well maintained na kotse from a car dealer. :sigh:
    Sent from my 3210 using Tapatalk HD Premium
    Apr 2013
    Quote Originally Posted by tagalnasaabroad View Post
    I am thinking of legal remedies but I will still try to fix it. thanks po
    Apr 2013
    Yup car dealer.
    Oct 2005
    btw, just so you know. normal lang po sa Vios gen2 na nag ba-vibrate ng malakas kapag tinanggal/kabit battery. because the ECU relearns your system. pero you just have to rev hard for about 2 or so minutes mag OK na ulit sya.
    hirap nangyari sayo. sana maayos yang oto, if i were you tatakutin ko na lang pinagbilhan mo, sabihin mo buy back or pag hindi papa halungkat mo history nyan, pag nalaman mo kamo na meron syang hindi dineclare na bad history yan, kakasuhan mo sya.
    Review your deed of sale, mayroon clause na "as-is, where is" yan and that's what the dealer will use as his escape clause. However, you can still consult a lawyer and find out your legal remedies or still try pakiusap with the seller before anything else.
    Was the MAF sensor cleaned already? What is the mileage of the Vios? Did you verify this with the service booklet and CASA records?
    Oct 2005
    I think this could still fall under Nature and Effect of Obligations; Art.1170 under "Fraud". Consult a lawyer.
Problem with my toyota vios 1.3E M/T
